Models from Devo 8s to Jumper T8SG
- Ariete
- Topic Author
20 Jan 2018 18:48 #67017
by Ariete
Models from Devo 8s to Jumper T8SG was created by Ariete
I am going to port my models from my Devo 8S to a Jumper I just bought.
Other than the icons that must be black and white, what else do I need to modify in the models file?
20 Jan 2018 18:52 #67018
Replied by FDR on topic Models from Devo 8s to Jumper T8SG
All the switches...
- Ariete
- Topic Author
20 Jan 2018 19:07 #67020
by Ariete
Replied by Ariete on topic Models from Devo 8s to Jumper T8SG
Do they have different names or is it just that there are fewer of them?
20 Jan 2018 19:34 #67022
Yep, there are fewer of them (however all of them are 3 state ones), and also have different names.
- Ariete
- Topic Author
20 Jan 2018 19:52 #67023
by Ariete
Thanks,
seems I will have to rewrite every model.
- Ariete
- Topic Author
27 Jan 2018 13:28 - 27 Jan 2018 13:29 #67214
by Ariete
Much to my surprise once you load the model in the Jumper Deviation rewrites the ini file with the correct switches names.
I didn't have to do do anything other than change icon and my model for UMX PT17 with Sport Cub S receiver is working flawlessly. The cut switch, the flying mode switch the panic switch all are working and in the correct position.
Last edit: 27 Jan 2018 13:29 by Ariete.
- Brett_N
05 Feb 2018 14:43 #67405
by Brett_N
Replied by Brett_N on topic Models from Devo 8s to Jumper T8SG
Ariete - Can you post up that .ini file?
Need one that works with flying mode.
- Ariete
- Topic Author
05 Feb 2018 19:33 #67409
by Ariete
No problem, but you need a SAFE receiver. Here it is.
Flight modes are in switch A:
Hope this helps.
- 0- Beginner
- 1- Intermediate
- 2- Advanced
- 0- No panic
- Else Panic
Hope this helps.
- Brett_N
18 Feb 2018 03:19 #67565
by Brett_N
Just a quick thanks - this works perfectly with my Carbon Cub with SAFE + GPS.
(Although, Switch D seems to be throttle ARM and Dual Rate)
Time to create page: 0.041 seconds
- Home
- Models from Devo 8s to Jumper T8SG
