Models from Devo 8s to Jumper T8SG
20 Jan 2018 18:48 #67017 by Ariete
Models from Devo 8s to Jumper T8SG was created by Ariete
I am going to port my models from my Devo 8S to a Jumper I just bought.
Other than the icons that must be black and white, what else do I need to modify in the models file?
20 Jan 2018 18:52 #67018 by FDR
Replied by FDR on topic Models from Devo 8s to Jumper T8SG
All the switches...
20 Jan 2018 19:07 #67020 by Ariete
Replied by Ariete on topic Models from Devo 8s to Jumper T8SG
Do they have different names or is it just that there are fewer of them?
20 Jan 2018 19:34 #67022 by FDR
Yep, there are fewer of them (however all of them are 3 state ones), and also have different names.
20 Jan 2018 19:52 #67023 by Ariete
Thanks,
seems I will have to rewrite every model.
27 Jan 2018 13:28 - 27 Jan 2018 13:29 #67214 by Ariete
Much to my surprise once you load the model in the Jumper Deviation rewrites the ini file with the correct switches names.:cheer: :cheer:
I didn't have to do do anything other than change icon and my model for UMX PT17 with Sport Cub S receiver is working flawlessly. The cut switch, the flying mode switch the panic switch all are working and in the correct position.
Last edit: 27 Jan 2018 13:29 by Ariete.
05 Feb 2018 14:43 #67405 by Brett_N
Replied by Brett_N on topic Models from Devo 8s to Jumper T8SG
Ariete - Can you post up that .ini file?
Need one that works with flying mode.
05 Feb 2018 19:33 #67409 by Ariete
No problem, but you need a SAFE receiver. Here it is.
File Attachment:
File Name: model1.ini
File Size:8 KB
Flight modes are in switch A:
  • 0- Beginner
  • 1- Intermediate
  • 2- Advanced
Panic is in switch B
  • 0- No panic
  • Else Panic
Throttle cut is in switch D and C is used to reset the timer.
Hope this helps.
18 Feb 2018 03:19 #67565 by Brett_N
Just a quick thanks - this works perfectly with my Carbon Cub with SAFE + GPS.
(Although, Switch D seems to be throttle ARM and Dual Rate)
Time to create page: 0.041 seconds
