JD 395 cx-10
- racemaniac
![:D :D](/media/kunena/emoticons/laughing.png)
One tip since the cx-10 (and 10a) have 3 modes: the middle mode mode is a bit past halfway towards the third mode on the axis. For my cx-10a i configured it with an offset of 115, and now it switches between high rate mode & headless
![:) :)](/media/kunena/emoticons/smile.png)
Also love the range i now get with my cx-10
- T.N.
vasiliy_gr wrote: Tested. Ch7 now ok. So all the extra functions of DM007 are working now.
Can you please post your dm007 ini file?
- vasiliy_gr
Here is my ini for dm007 on 7e with two extra 3x switches. It may have some defects as I am really got mixed up with testing on two devo's four new quads with test builds... But I checked it right now - it is flyable.T.N. wrote:
SWB for speed rate (low-medium-high), FMODE for flips (you need it ON - flip - OFF - ON again - flip again), HOLD for headless, UP and DN for photo/video (or vice versa - do not remember exactly).
- T.N.
- czajunia
- goebish
- I Void Warranties
Channel 6: flip
- czajunia
- goebish
- I Void Warranties
- czajunia
- goebish
- I Void Warranties
chan5 >=0 && <50% then flag = 1 (mid rate, or high rate on cx10a)
chan5 >= 50% then flag = 2 (high rate, or headless on cx10a)
- czajunia
For some reason I cannot get the 3-way switch to work for me. I am using Expo&DR template and trying to assing fixed curve to each switch value: SW0 = -90, SW1 = 0 and SW2 = 90. As a result I can only switch between one rate and the headless mode. Meaning that going from SW0 to SW1 doesn't do anything and going from SW1 to SW2 switches the headless mode ON. Any ideas what I am doing wrong?
- goebish
- I Void Warranties
- czajunia
Worked like a charm. Thanks!goebish wrote: try a bit more than 0 for sw1
I have one more question regarding setting up the Channel6. Probably a very easy fix but I can't figure it out. I can make the flips work, no problem. However when I change a switch on Ch6 it only does one flip and I need to change the position to 0 and then back to 1 to make another flip. Is there way to either:
1. Make the quad stay in the flip mode until the switch is put back from 1 to 0.
2. Make it go to the flip mode every time the state of a switch is changed - regardless if going from 0 to 1 or if going from 1 to 0 (not just when changing from 0 to 1).
- goebish
- I Void Warranties
![;) ;)](/media/kunena/emoticons/wink.png)
- czajunia
Not a major issue for me to be honest. It was more of an exercise trying to make it work. I can always assign one of the trim switches if I want to have a similar behavior to the stock transmitter. Cheers.
EDIT: With trim switches it works kinda the same way actually. To do a flip a trim button needs to be pushed twice. I'll stick to the FMOD switch then
- Batam
I have a CX-10 with red PCB, but it doesn't have the wire antenna and is working with XN297.
Is it another new version or is it like blue one (the layout is not exactly the same) ?
No chance to see it working with deviation I guess.
Thanks.
- goebish
- I Void Warranties
- Batam
![:-) :-)](/media/kunena/emoticons/smile.png)
EDIT : Or if someone tells me how to do it.
- goebish
- I Void Warranties
- Batam
- JD 395 cx-10
