JD 395 cx-10
- IKKI
sledgehammer1570 wrote:
I have a Juncheng Mini Drone 3015-2. I tried your build. CX-10 and green protocol option but it won't bind. I've heard that there are two protocols for this quad. I believe i have the early one. Happen to know which one you got? I mean did I do something wrong or is it just different protocol.goebish wrote: Here's a test firmware for Juancheng, select Green protocol, then there are 2 extra options in protocol options, P13 and P14, ranging from 0 to 7.
Try each values, check if it activates a feature, then report
www.dropbox.com/s/q4o3lpwi750uuv2/deviat...0.1-2cde795.zip?dl=0
Very strange, I have both the old version and new version 3015-2, and camera version 3015-1 have the same protocol.
- sledgehammer1570
goebish wrote: If it doesn't bind with green format option then it's another protocol.
I suppose you've tried Blue/A format too ?
Get a logic analyzer and dump the stock TX if you want me to have a look ...
Yeah i tried it. I'd love to do so but lacking skills and equipment
![:S :S](/media/kunena/emoticons/dizzy.png)
IKKI wrote: Very strange, I have both the old version and new version 3015-2, and camera version 3015-1 have the same protocol.
I saw some youtuber once. Said he ordered a second "mini drone" and couldn't bind the old tx into it.
- IKKI
or In this case.... Order another one, maybe 3015-1
![;) ;)](/media/kunena/emoticons/wink.png)
- sledgehammer1570
IKKI wrote: analizer... www.ebay.com/sch/i.html?_from=R40&_sacat...rksid=p2045573.m1684
Here's my procedure: (i'm new to deviation)
I have Devo 7e with nrf24l01 module. Binds at least with bayang and v202 -> Cleaned the disk/drive of the devo before updating to goebish's dfu. -> Import the latest nightly build and then import the protocol folder from goebish's .zip and replace all -> in hardware.ini " enable-nrf24l01 = A13 " -> In deviation, swich to multi and browse for the cx-10 protocol, green option. -> hit re-init -> nothing happens with 3015-2..
Something go wrong? I wouldn't bother ordering another 3015-2. I could imagine getting that analyzer. I assume there is some topic where I could learn how to use that?
![:) :)](/media/kunena/emoticons/smile.png)
- IKKI
The procedure seems the right one. The only thing I can report is that my bind after the third beep. It takes a few seconds. You have no way of making further verification protocol with other radio control toy? I'm reading here to learn to acquire.
www.deviationtx.com/forum/protocol-devel...guide?start=20#38618
- goebish
- I Void Warranties
- Juncheng 3015-2: we found the flag for "double flip", but does it still have "single flip" too ?
- Mould King 33041: which channels are reversed compared to the "Green" protocol, Aileron and Elevator ?
- IKKI
![:P :P](/media/kunena/emoticons/tongue.png)
edit: ok, AIL and ELE inverted on CX10 green standard protocol
- goebish
- I Void Warranties
<= 0 -> no flip
< 50 -> single flip
> 50 -> double flip
- Durete
goebish wrote: Ok, I'll use a single channel (6) for flips on Juncheng 3015-2:
<= 0 -> no flip
< 50 -> single flip
> 50 -> double flip
IMO right choice, to keep the standard channel map
- goebish
- I Void Warranties
Durete wrote: IMO right choice, to keep the standard channel map
Yup, but I'll have to make an exception for leds on Juncheng 3015-2 because channel 5 is already used for "rate".
- vasiliy_gr
No. They both are reversed on DM007 option. On Green option only ELE is reversed.goebish wrote: - Mould King 33041: which channels are reversed compared to the "Green" protocol, Aileron and Elevator ?
- goebish
- I Void Warranties
... what a mess
![:p :p](/media/kunena/emoticons/tongue.png)
- Durete
Yep, the "standard map" is light control.
Doesn't have light control the 3015-1/2 ?
Yup, I missed the light control on 3015-2
- goebish
- I Void Warranties
- Durete
- IKKI
https://youtu.be/x69Xx0PHLaU
even if the price is low as the quality, to know how to use not just be thrown away! : D
- goebish
- I Void Warranties
www.dropbox.com/s/bj3ey2q0loy1t7k/deviat...0.1-ddc8b89.zip?dl=0
Source code:
bitbucket.org/goebish/deviationtx/branch/protocol_q282#diff
It has CX10 Green, Blue-A, WLToys Q282 (thanks hexfet), DM007, JC3015-1, JC3015-2 and MK33041 format options.
Channel 5 controls rate (except on Q282: controls lights)
Channel 6 controls flips (double flips if >50 on JC3015-2)
Channel 7 controls picture snapshot (except on JC3015-1: controls lights)
Channel 8 controls video recording (requires toggle to start/stop on some models)
Channel 9 controls headless
Channel 10 controls RTH
Please report, could be cool to re-check CX10 and DM007 to make sure I didn't break anything.
- IKKI
Now i try this version! Thank you!
![:D :D](/media/kunena/emoticons/laughing.png)
- vasiliy_gr
UPD: Sorry, retried dl with walkera tools - now it's ok. The problem was with DeviationUpload-0.8.0.jar.
- IKKI
- JD 395 cx-10
