SYMA X5C-1, X11, X12
- ahuttere@gmail.com
- john
IS JJRC H5C same protocol Syma X5C ? or other protocol ? v2x2 ?
- Durete
- SeByDocKy
- Topic Author
In order to match the V2x2 (now with 3 new channels: headless, gyro-x, gyro-y) & the Flysky (now with headless, light, RTH, flip, gyro-x, gyro-y) protocols channels assignation, I propose to modify this syma's protocol channel asignation
fllip => Channel 6
Picture = > Channel7
Video = > Channel8
I will capture Headless channel => Channel 9 for Syma protocol (Syma X5SC & X8C have this new feature)
With this standardization, whatever, V2x2, FlySky and Syma, config files will remain identical ...
I agree it would be nice if they were consistent, but I'm not sure it's a good idea to make a change that will break existing SymaX and YD717 model files. Opinions?
- victzh
- victzh
- Durete
Will be a good idea for new or updated protocols, but IMO a bad idea for existing and consolidated protocols
I'm not sure how to detect this case in the Tx if we actually want to change the option order for something in a previous release. we could add a protocol API version and disable the protocol if it doesn't match, but that may be a lot of work for little gain.
- SeByDocKy
- Topic Author
Durete wrote: I agree Hexfet. It would be nice same channel layout for all protocols, but these change will break all existing model files.
But with unified mapping, you will need only one unique model file skeleton ....
- mugen0001
Contrary to what I posted above, SymaX doesn't have light controls The change will be:
Channel old new
5 flip
6 picture flip
7 video picture
8 video
Really don't want to see any "deviation changed and crashed my quad" posts, so please spread the word if this change gets merged. The Syma flip is fully automatic so hopefully will be manageable even if unexpected.
Agree it's not worth the effort of versioning or making a separate protocol, especially since it's not in a released version. Since YD717 was in 4.01 it won't change.
Not everyone has to add new models as often as SeByDocKy, but he'll also have the most models to change!
- SeByDocKy
- Topic Author
hexfet wrote: I'll make a pull request to change the control channels for SymaX. I think it will be more beneficial to newcomers to Deviation than it will be detrimental to users who install the nightly builds. Maybe we can add an "RTF quad" template usable with v202, flysky, and symax.
Contrary to what I posted above, SymaX doesn't have light controls The change will be:Channel old new 5 flip 6 picture flip 7 video picture 8 video
Thanks a lot .... I will capture as soon I can the headless channel to end with this new Syma protocol ...
From now, it would be a good idea to keep this channels'order ...in future protocol hacking ...
- SeByDocKy
- Topic Author
mon-partage.fr/f/le6487qE/
- John-Boy
How about adding a column to the 'Supported Models' document that contains a link to a working INI file for that model?
The unique model INI file would move the channels around and not require all kinds of options to be included in the protocols. Lots of options/versions would make them cumbersome and prone to setup errors by new users.
Also, it would really show off the huge list of models that Deviation supports. Easy to get your favorite model in the air with one-stop at the Deviaton site...
Jm2c...
1) find your vehicle in the table
2) verify you have the proper module installed and working
3) copy the ini from the linked thread to the tx
4) go out flying
Things are a little complicated at the moment with respect to module installation (due to changes between 4.0.1 and the nightlies) but once we make the next release, that should be cleared up.
Thanks for capturing this. Which Syma model did you use for the capture? Can you control that model with the SymaX protocol? The capture shows two different bind packets being sent, with 1 of the four rf channels used for binding being different than SymaX. The rf chip initialization is different too, but haven't looked at the details yet.SeByDocKy wrote: Here is the SPI capture of the headless mode for the new Syma protocol (@250Kbits)
The headless mode is controlled by the most significant bit in the eighth byte of the data packet.
- SeByDocKy
- Topic Author
It's a SYMA X5C. In fact, I didn't bind the quadcopter ... but yes I can control perfectly the quad with your new syma implementation...
Maybe do you want some new capture with the quad turned on too ?
- SeByDocKy
- Topic Author
- Durete
SeByDocKy wrote: It's a SYMA X5C. In fact, I didn't bind the quadcopter ... but yes I can control perfectly the quad with your new syma implementation...
Maybe a Syma X5S (Explorers 2) ? not an X5C
- Home
- Development
- Protocol Development
- SYMA X5C-1, X11, X12
