Eachine E010 inductrix clone data captures
27 Aug 2016 13:48 #53135 by HappyHarry
Eachine E010 inductrix clone data captures was created by HappyHarry
hi guys, i have captured the data from the eachine e010 transmitter in hopes of the protocol being hacked, the files, and a description of the settings and capture files are included in the zip file >> www.dropbox.com/s/37qz9wj2u6v0u6r/E010-Samples.7z?dl=0
if you need any more samples let me know, and thanks in advance if anyone tackles this protocol :)
  • goebish
  • goebish's Avatar
  • Away
  • NRF Weirdo
27 Aug 2016 14:01 #53136 by goebish
Replied by goebish on topic Eachine E010 inductrix clone data captures
Thank you very much for the captures :)
I'm very glad to see it's using a xn297l, I'll have a look at your captures and I should receive mine soon, it's been shipped 1 week ago :)
  • goebish
  • goebish's Avatar
  • Away
  • NRF Weirdo
27 Aug 2016 14:06 - 27 Aug 2016 14:29 #53137 by goebish
Can you recapture with a higher bitrate please ? 200khz is not enough, try 16MHz ;)
Last edit: 27 Aug 2016 14:29 by goebish.
27 Aug 2016 15:50 - 27 Aug 2016 16:34 #53139 by HappyHarry
Replied by HappyHarry on topic Eachine E010 inductrix clone data captures
no problem, I'll get them up soon, by the way do the captures look ok data wise? as in will 3wire spi still be hackable?
Last edit: 27 Aug 2016 16:34 by HappyHarry.
  • goebish
  • goebish's Avatar
  • Away
  • NRF Weirdo
27 Aug 2016 17:06 #53143 by goebish
I don't know if data is fine as bitrate is too low.
I don't think it's 3 wire SPI, just that MISO isn't connected, but even if it was 3 wire SPI no problem.
27 Aug 2016 18:05 #53144 by HappyHarry
no probs, I was worried when I saw the 8pin version of the xn didn't have the full spi pinout, only clk, csn and data. I'll be home in about 30mins so expect the new captures within the hour bud
27 Aug 2016 18:32 #53145 by HappyHarry
ok new captures are up, let me know if they are ok or if you need anything else done 8)
  • goebish
  • goebish's Avatar
  • Away
  • NRF Weirdo
27 Aug 2016 18:35 #53146 by goebish
Looks fine, I'll try to take a further look this evening :)
27 Aug 2016 18:46 #53147 by HappyHarry
many thanks, and good luck :)
  • goebish
  • goebish's Avatar
  • Away
  • NRF Weirdo
27 Aug 2016 18:47 #53148 by goebish
Seems simple, expect a test build soon ;)
27 Aug 2016 18:54 #53149 by rasqba
Replied by rasqba on topic Eachine E010 inductrix clone data captures
goebish wrote: Seems simple, expect a test build soon ;)
Unbelievable, how can I buy you a beer? :D Thanks for the work man
27 Aug 2016 19:23 #53151 by HappyHarry
awesome :D i have both a modded 7e and an ultimate7e so a build for either of those would be great, or if you push the code to your deviation repo i can pull and build them myself to save you time :)
  • goebish
  • goebish's Avatar
  • Away
  • NRF Weirdo
27 Aug 2016 20:33 #53156 by goebish
I'll try to implement it as an mjqx protocol format option, they're quite similar.
27 Aug 2016 21:16 #53158 by Soulsmoke
Replied by Soulsmoke on topic Eachine E010 inductrix clone data captures
Great news!
I have had mine for a day or so and it flies really well, quite smooth and precise once you get past the teeny transmitter. My gimbles felt very dry and creaky out of the box so I whipped it open and lubed it a bit, better now but using the Devo would just be the icing on the cake.
What module will this be using? I have a NRF sitting in my parts box but not having anything to bind it to I am yet to install.
Thanks for the work on this :)
  • goebish
  • goebish's Avatar
  • Away
  • NRF Weirdo
27 Aug 2016 21:17 #53159 by goebish
It will be using the nrf24.
Stay tuned, I should have something for you to test in a few minutes ;)
  • goebish
  • goebish's Avatar
  • Away
  • NRF Weirdo
27 Aug 2016 21:27 - 27 Aug 2016 21:49 #53160 by goebish
Here's a test build, no idea if it will work ;)
- there's only 1 fixed txid for now ...
Select Mjqx protocol, E010 format option.
Devo 7e
Devo 10
Please report :)
edit: I made a mistake ... rebuilding
edit2: ok, please download again ...
Last edit: 27 Aug 2016 21:49 by goebish.
27 Aug 2016 21:46 - 27 Aug 2016 21:47 #53161 by HappyHarry
sorry bud it's not binding, edit sorry i'll try the second version and report back
Last edit: 27 Aug 2016 21:47 by HappyHarry.
27 Aug 2016 21:47 #53162 by HappyHarry
the link isn't working bud
  • goebish
  • goebish's Avatar
  • Away
  • NRF Weirdo
27 Aug 2016 21:49 #53163 by goebish
Fixed ;)
27 Aug 2016 21:59 #53164 by HappyHarry
still no luck bud, i tried extending the range of the throttle channel to make sure it was recieving a full +100/-100 to see if that helped the bind but no luck
Time to create page: 0.062 seconds
