Eachine E010 inductrix clone data captures
10 Sep 2016 08:53 #53715 by goebish
Replied by goebish on topic Eachine E010 inductrix clone data captures
You've selected the WLH08 format instead of E010, no wonder it doesn't work ;)
Try with the attached one ...
10 Sep 2016 08:56 #53716 by Stecozz
Replied by Stecozz on topic Eachine E010 inductrix clone data captures
Thanks for your help goebish
10 Sep 2016 09:06 #53717 by Stecozz
How do i select the E010 format?
just put loaded your file in the models and it still doesnt bind.
10 Sep 2016 09:11 - 10 Sep 2016 09:12 #53718 by goebish
Highlight "MJXq" in Model setup menu, press enter then select E010 sub-format.
Start from a fresh model, I see some stuffs are missing in your .ini ...
Last edit: 10 Sep 2016 09:12 by goebish.
10 Sep 2016 09:13 #53719 by Alias_Hendrik
Replied by Alias_Hendrik on topic Eachine E010 inductrix clone data captures
I fiddled some more but can't get headless to work properly. When i push left hor. trim button the led on the E010 start blinking indicating headless.
As long as the rear of the quad is facing to me it flies but as soon as i turn the E010 for 180 degree the problem starts. Meaning aileron stick to the right i need a lot of stick travel to get it flying in that direction.
But with barely any aileron stick to the left it's shooting left like a rocket and i need full right stick to stop it and i need to keep the stick almost full right to prevent it going further to the left. The same happens with forward and back movement when the quad is turned 180 degrees in headless mode.
I don't know what i'm doing wrong so i gave up. Perhaps someone can share an ini with a correct working headless mode thanks.
10 Sep 2016 09:18 #53720 by goebish
@Alias_Hendrik I think I understand, I should disable dynamic trims while headless is enabled ... I'll fix that.
10 Sep 2016 09:24 #53721 by Stecozz
goebish wrote: Highlight "MJXq" in Model setup menu, press enter then select E010 sub-format.
my only options are WLH08,X600,X800,H26D?
10 Sep 2016 09:25 - 10 Sep 2016 09:25 #53722 by goebish
That means you haven't flashed the latest .dfu and copied the .mod files (you're running an older version of deviation).
Install the latest nightly.
Last edit: 10 Sep 2016 09:25 by goebish.
10 Sep 2016 09:30 #53724 by Alias_Hendrik
Thanks! i had a slight feeling it had something to do with dyntrim added or substracted in a particular direction. So in that case my ini should be ok ;)
I looked at the ini you posted, and for ch3 i noted scalar and scalar min = 150 should i add that to my ini? Thanks.
10 Sep 2016 09:30 #53725 by goebish
@Alias_Hendrik, can you check if this build fixes the issue with headless mode please ?
Devo 7e
10 Sep 2016 09:38 #53727 by Stecozz
goebish wrote: That means you haven't flashed the latest .dfu and copied the .mod files (you're running an older version of deviation).
Sorry about this.
Do i delete all my files and replace the whole lot with the nightly?
What about the debug zip file?
10 Sep 2016 09:59 #53728 by William
Replied by William on topic Eachine E010 inductrix clone data captures
Hello, je doit installer deviation-devo7e-256-v5.0.0-28fd02d.zipdeviation-devo7e-256-v5.0.0-28fd02d.zip or deviation-devo7e-v5.0.0-28fd02d.zipdeviation-devo7e-v5.0.0-28fd02d.zip ?
William
10 Sep 2016 10:12 #53729 by Stecozz
Be good to have instruction on how to install "nightly builds"
For NooBs
10 Sep 2016 10:15 - 10 Sep 2016 10:18 #53730 by goebish
Nightly builds (and test builds) have nothing special, just install it as you installed deviation on your transmitter initially, flash the .dfu then overwrite the .mod files in the protocol folder.
www.deviationtx.com/downloads-new/category/13-nightly-builds
The debug file is only intended to developers, you don't have to worry about it.
Last edit: 10 Sep 2016 10:18 by goebish.
10 Sep 2016 10:20 #53731 by goebish
@William, if you've a devo 7e with stock MCU then you want the devo7e version, not devo7e-256.
10 Sep 2016 10:21 #53732 by goebish
Hmmm, I feel like a support / help thread should be opened for this (already popular) model and keep this thread for development purposes ;)
10 Sep 2016 10:28 #53733 by Alias_Hendrik
goebish wrote: @Alias_Hendrik, can you check if this build fixes the issue with headless mode please ?
Devo 7e
Installed the build but the E010 refuses to bind. I checked for the correct version on my 7E and it's installed.
10 Sep 2016 10:38 #53734 by William
oups! the MCU ? j'ai ça nRF24L01 CC2500 a7105 plusieurs rf 3 en 1 module sans fil pour l'émetteur de devo instalé sur ma devo 7e, c'est le MCU?
William
10 Sep 2016 10:40 - 10 Sep 2016 10:46 #53735 by goebish
Devo 7e
I noticed that it wouldn't completely bind with some txid (the protocol is not fully cracked, I'm waiting for more captures ...), try with a different fixed transmitter ID.
Disconnect / reconnect battery on the quad between tries because it get stuck when trying to bind with a non working ID.
Last edit: 10 Sep 2016 10:46 by goebish.
10 Sep 2016 10:43 #53736 by goebish
William wrote: oups! the MCU ? j'ai ça nRF24L01 CC2500 a7105 plusieurs rf 3 en 1 module sans fil pour l'émetteur de devo instalé sur ma devo 7e, c'est le MCU?
No, the MCU is the processor of your transmitter (STM32), if it's unmodified then you need the devo7e version, not 256.
Please try to use english on this forum ;)
Time to create page: 0.086 seconds
