Bugs 3 mini
15 Oct 2018 21:55 #71385 by JayDrone
Replied by JayDrone on topic Bugs 3 mini
or u actually click the bugs3mini protocol ad add it there
15 Oct 2018 21:57 #71386 by goebish
Replied by goebish on topic Bugs 3 mini
yes, that's what I told you in the previous page ;)
15 Oct 2018 21:58 #71387 by JayDrone
again im working on the t8sg plus if u could make a video id be very greatful i have the dfu file on the plus and I have the drone ready to go sorry def not a tech guy
15 Oct 2018 21:58 #71388 by goebish
I won't make a video, sorry but I can't make it more simple than the step by step post ...
15 Oct 2018 22:02 #71389 by JayDrone
i might get it now -- stand by n I will try -- again no tech guy - fell into this hobby as i love to fly n in 2 years have absorbed alot but u guys over here are KINGS on this ty for ut time
15 Oct 2018 22:07 #71390 by JayDrone
after address is in bind quad up ?
15 Oct 2018 22:09 #71391 by goebish
Yes the quad should bind if you entered the right address for your rx id.
15 Oct 2018 22:10 #71392 by JayDrone
cool ty much
15 Oct 2018 22:21 #71393 by planger
Replied by planger on topic Bugs 3 mini
goebish wrote: I noticed there was a few errors the first time I dumped it, I fixed a few manually but probably missed some.
I made a 2nd capture which should be fine (more checks), it's in my dropbox folder:
www.dropbox.com/sh/nrc4oppo121887l/AABQ_...IEn8A7BYvH5BpGa?dl=0
3010,30 3d 10 a9 ce ,12304,-50
Much more better.
Not fully tested yet but I've simplified the huge table translating rxid to address with a table of 23 * 4 bytes = 92 bytes. It needs a maximum of 23*255 trials/loops to find the right txid which needs to be done only once at bind time.
I'll see if I can compact it even more but that's already a good start to get something working.
Time to sleep, more tomorrow.
Pascal
15 Oct 2018 22:25 #71394 by JayDrone
worked flawlessly
15 Oct 2018 22:47 #71395 by C0ckpitvue 777
Replied by C0ckpitvue 777 on topic Bugs 3 mini
JayDrone wrote: worked flawlessly
Jay if you got time to post your model ini.,for others it'll really help a lot of people with the jumper or a how to video also mentioning your jumper version.
15 Oct 2018 22:50 - 15 Oct 2018 22:57 #71396 by planger
planger wrote: Ok, I've now reduced the table to 23*2 bytes = 46 bytes.
Pascal
Last edit: 15 Oct 2018 22:57 by goebish. Reason: oops
15 Oct 2018 22:58 #71397 by goebish
Good job!
46 bytes instead of 128kB!
15 Oct 2018 23:36 #71399 by JayDrone
i know u seen it already but here u guys go the little i can do on my end im good at making vids lol -- u guys got crazy skills developing these updates -- thanx a bunch this should make the b3mini back into rotation
16 Oct 2018 01:34 #71401 by Einsteins
Replied by Einsteins on topic Bugs 3 mini
hellow guys
i just followed tutorial step by step with latest build
im using jumper t8sg v2 plus
when bind process, it working, and i got rxid (green column)
but when i put address follow the list (blue column)
and rebind on off transmitter, the drone couldn't connect
i need help here :lol:
hey i try bind mjx b3h with this protokol, it working, really good
all channel is supported, arming, led, flip, swith altitude hold on off
thank you so much guys
16 Oct 2018 10:48 #71407 by goebish
Perhaps that's a mistake in the table, can you give me your rxid ?
16 Oct 2018 11:22 - 16 Oct 2018 11:26 #71408 by planger
goebish wrote: Good job!
100% match of your extracted table and my code :woohoo:
Here is the rxid2txid function:
void rxid2txid(uint8_t rxid_high, uint8_t rxid_low)
	uint8_t start, length, index;
	static const uint16_t end[]={
		0x2d9e, 0x95a4, 0x9c5c, 0xb4a6, 0xa9ce, 0x562b, 0x3e73, 0xb895, 0x6a82, 0x9437, 0x3d5a,
		0x4bb2, 0x6949, 0xc224, 0x6b3d, 0x23c6, 0x9ea3, 0xa498, 0x5c9e, 0xa652, 0xce76, 0x2b4b, 0x733a };
	if(rxid_high==0x00 || rxid_high==0xFF)
		rx_tx_addr[0]=0x52;
	else
		rx_tx_addr[0]=rxid_high;
	rx_tx_addr[1]=0x3d;
	if(rxid_low==0x00 || rxid_low==0xFF)
		rx_tx_addr[2]=0x66;
	else
		rx_tx_addr[2]=rxid_low;
	for(uint8_t end_idx=0;end_idx<23;end_idx++)
		//calculate sequence start
		if(end_idx<=7)
			start=end_idx;
		else
			start=(end_idx-7)*16+7;
		//calculate sequence length
		if(end_idx>6)
			if(end_idx>15)
				length=(23-end_idx)<<1;
			else
				length=16;
		else
			length=(end_idx+1)<<1;
		//scan for a possible solution using the current end
		for(uint8_t i=0;i<length;i++)
			index=(i>>1)*7+(((i+1)>>1)<<3);
			index=start+index-rxid_high;
			if(index==rxid_low)
			{ //solution found
				rx_tx_addr[3]=end[end_idx]>>8;
				rx_tx_addr[4]=end[end_idx];
				return;
	// Something bad happened if we arrive here....
Pascal
Last edit: 16 Oct 2018 11:26 by planger.
16 Oct 2018 11:23 #71409 by goebish
Thank you very much for your hard work, I'll try that right away :)
16 Oct 2018 11:31 - 16 Oct 2018 11:43 #71410 by planger
I'm not sure if it can be simplified further. It's already pretty straigth forward...
It can take up to 23*256 iterations to find the tx address depending on the rxid value. But it should be pretty quick anyway since the calculations are quite simple. It can be speed up by pre calculating a table upfront but it would cost 16 bytes of ram, I haven't done it since I think you are always short in ram usage?
I would save the rxid (2 bytes) and always call the function to get the tx address when needed at init and bind.
Pascal
Last edit: 16 Oct 2018 11:43 by planger.
16 Oct 2018 11:55 - 16 Oct 2018 12:12 #71411 by goebish
Works perfectly on my end, test build updated, spreadsheet isn't required anymore for initial bind!
(we still have to store Rx Id in protocol options but just ignore it ...)
Channel 5: Arm
Channel 6: Leds on/off
Channel 7: Flip mode
Channel 8: Snapshot (requires mjx wifi camera module)
Channel 9: Record video (requires mjx wifi camera module)
Channel 10: Angle / Acro mode
source: github.com/goebish/deviation/blob/protoc...bugs3mini_nrf24l01.c
Last edit: 16 Oct 2018 12:12 by goebish.
Time to create page: 0.091 seconds
