Bugs 3 mini
05 Jun 2018 00:29 #69547 by C0ckpitvue 777
Bugs 3 mini was created by C0ckpitvue 777
Here are the captures for the bugs 3 mini,note there are 2 different modes angle and acro,the quadcopter has to be rebound in order to move from these 2 modes,I took captures of both modes if you need anything more just let me know,thank you very much.
www.mediafire.com/file/l8zij9hqddlrmtc/B...0Mini%20Captures.zip
05 Jun 2018 07:28 #69554 by goebish
Replied by goebish on topic Bugs 3 mini
Thanks ;)
05 Jun 2018 20:52 #69561 by DPyro
Replied by DPyro on topic Bugs 3 mini
Can you post a picture of the pins you soldered to? Just got my analyzer in the mail so I can make some captures as well.
05 Jun 2018 20:54 #69562 by goebish
Nice, because I had a quick look and several captures will be necessary to understand the protocol.
05 Jun 2018 23:12 #69563 by C0ckpitvue 777
Replied by C0ckpitvue 777 on topic Bugs 3 mini
To be honest I soldered all the pins except the vcc and forgot which color is soldered to which pin because I g0t a big glob of hot glue over the pins.I just hooked all 7wires to the analyzer the 2nd pin is the ground and the first is the vcc.
05 Jun 2018 23:13 #69564 by C0ckpitvue 777
Can I help with the captures.which captures do you need?
06 Jun 2018 08:07 #69566 by goebish
Do you have several transmitters or bugs mini ?
06 Jun 2018 09:02 #69567 by C0ckpitvue 777
I just got 1 setup...
06 Jun 2018 09:04 #69568 by goebish
Ok, I need captures from several setups to understand the handshake during bind.
07 Jun 2018 00:04 #69573 by C0ckpitvue 777
Somebody mentioned something about taking captures but the names aren't showing up on the threads anymore.
07 Jun 2018 00:06 #69574 by goebish
Yeah, this forum bug is annoying :P
I think the user is DPyro
07 Jun 2018 02:17 #69576 by DPyro
I need to know where to solder.
07 Jun 2018 02:40 #69577 by C0ckpitvue 777
Ok sorry,you don't have to solder the first pin the 1 circled is the ground (2nd pin) .I soldered all the pins to the right of the ground and just hooked them up to the analyzer,I think as long as you have the ground right the Professional Goebish can distinguish the 4 signals.
07 Jun 2018 04:16 #69578 by DPyro
Which pin goes to which channel on the analyzer? There are 8 channels plus two ground on the analyzer.
07 Jun 2018 08:21 - 07 Jun 2018 09:47 #69579 by goebish
That doesn't matter, just connect ground to ground then connect 6 channels to the 6 rightmost pins.
Last edit: 07 Jun 2018 09:47 by goebish.
08 Jun 2018 18:34 #69585 by DPyro
Here is my first capture. Let me know if its good.
10 Jun 2018 19:29 #69599 by goebish
doesn't look good, seems you're sampling at 50kHz only, use 16-20MHz instead.
10 Jun 2018 20:43 - 10 Jun 2018 20:48 #69600 by DPyro
Try this one
Bind + ARM.
Last edit: 10 Jun 2018 20:48 by DPyro.
10 Jun 2018 20:54 - 10 Jun 2018 21:02 #69601 by goebish
Last edit: 10 Jun 2018 21:02 by goebish.
10 Jun 2018 21:07 - 10 Jun 2018 21:12 #69602 by goebish
Looks like this machine has a bind sequence before it can be used (initial address are different between your dump & C0ckpitvue 777's ), I'd need a capture of that.
Last edit: 10 Jun 2018 21:12 by goebish.
Time to create page: 1.094 seconds
