Bugs 3 mini
- C0ckpitvue 777
05 Jun 2018 00:29 #69547
by C0ckpitvue 777
Bugs 3 mini was created by C0ckpitvue 777
Here are the captures for the bugs 3 mini,note there are 2 different modes angle and acro,the quadcopter has to be rebound in order to move from these 2 modes,I took captures of both modes if you need anything more just let me know,thank you very much.
www.mediafire.com/file/l8zij9hqddlrmtc/B...0Mini%20Captures.zip
- goebish
- NRF Weirdo
- DPyro
05 Jun 2018 20:52 #69561
by DPyro
Replied by DPyro on topic Bugs 3 mini
Can you post a picture of the pins you soldered to? Just got my analyzer in the mail so I can make some captures as well.
- goebish
- NRF Weirdo
05 Jun 2018 20:54 #69562
by goebish
Replied by goebish on topic Bugs 3 mini
Nice, because I had a quick look and several captures will be necessary to understand the protocol.
- C0ckpitvue 777
05 Jun 2018 23:12 #69563
by C0ckpitvue 777
Replied by C0ckpitvue 777 on topic Bugs 3 mini
To be honest I soldered all the pins except the vcc and forgot which color is soldered to which pin because I g0t a big glob of hot glue over the pins.I just hooked all 7wires to the analyzer the 2nd pin is the ground and the first is the vcc.
- C0ckpitvue 777
05 Jun 2018 23:13 #69564
by C0ckpitvue 777
Can I help with the captures.which captures do you need?
- goebish
- NRF Weirdo
06 Jun 2018 08:07 #69566
by goebish
Do you have several transmitters or bugs mini ?
- C0ckpitvue 777
06 Jun 2018 09:02 #69567
by C0ckpitvue 777
I just got 1 setup...
- goebish
- NRF Weirdo
06 Jun 2018 09:04 #69568
by goebish
Ok, I need captures from several setups to understand the handshake during bind.
- C0ckpitvue 777
07 Jun 2018 00:04 #69573
by C0ckpitvue 777
Somebody mentioned something about taking captures but the names aren't showing up on the threads anymore.
- goebish
- NRF Weirdo
07 Jun 2018 00:06 #69574
by goebish
Yeah, this forum bug is annoying
I think the user is DPyro
- DPyro
07 Jun 2018 02:17 #69576
by DPyro
I need to know where to solder.
- C0ckpitvue 777
- DPyro
07 Jun 2018 04:16 #69578
by DPyro
Which pin goes to which channel on the analyzer? There are 8 channels plus two ground on the analyzer.
- goebish
- NRF Weirdo
07 Jun 2018 08:21 - 07 Jun 2018 09:47 #69579
by goebish
That doesn't matter, just connect ground to ground then connect 6 channels to the 6 rightmost pins.
Last edit: 07 Jun 2018 09:47 by goebish.
- DPyro
08 Jun 2018 18:34 #69585
by DPyro
Here is my first capture. Let me know if its good.
- goebish
- NRF Weirdo
10 Jun 2018 19:29 #69599
by goebish
doesn't look good, seems you're sampling at 50kHz only, use 16-20MHz instead.
- DPyro
10 Jun 2018 20:43 - 10 Jun 2018 20:48 #69600
by DPyro
Try this one
Bind + ARM.
Bind + ARM.
Last edit: 10 Jun 2018 20:48 by DPyro.
- goebish
- NRF Weirdo
10 Jun 2018 20:54 - 10 Jun 2018 21:02 #69601
by goebish
Last edit: 10 Jun 2018 21:02 by goebish.
- goebish
- NRF Weirdo
10 Jun 2018 21:07 - 10 Jun 2018 21:12 #69602
by goebish
Looks like this machine has a bind sequence before it can be used (initial address are different between your dump &
C0ckpitvue 777's
), I'd need a capture of that.
Last edit: 10 Jun 2018 21:12 by goebish.
Time to create page: 0.647 seconds
- Bugs 3 mini
