Bugs 3 mini
15 Oct 2018 13:03 #71358 by C0ckpitvue 777
Replied by C0ckpitvue 777 on topic Bugs 3 mini
goebish wrote: Ok thanks, well, I prefer that, that should be a simple fix, I'm probably shutting down the transmitter too soon when switching to rx mode ...
No problem,I will continue to test them and give you feedback,,
15 Oct 2018 14:35 #71360 by goebish
Replied by goebish on topic Bugs 3 mini
Updated :)
15 Oct 2018 14:38 #71361 by C0ckpitvue 777
goebish wrote: Updated :)
Thanks I'll give it a go,
15 Oct 2018 16:37 - 15 Oct 2018 17:10 #71363 by planger
Replied by planger on topic Bugs 3 mini
goebish wrote: @Pascal, awesome! Feel free to do it if you understand how it works, no hurry.
There are a number of bad values in the excel file. Are you able to redo some of them?
Here are the rxid causing issues which are easy to pinpoint: 0500,0af9,3010,3048,305a,30b9,8c30,d830,eb30,61a3,6d97
For example, 3010 -> 3d 10 a9 ce 00 where it should be 30 3d 10 a9 ce . Others in the list have either a mising byte or what looks like to be an old buffer entry.
There are a couple more which looks abnormal than the list above but the ones provided are for sure bad.
I'm progressing on reversing the table. It's based on a circular buffer as stated previously.
Pascal
Last edit: 15 Oct 2018 17:10 by planger.
15 Oct 2018 17:09 - 15 Oct 2018 17:15 #71364 by goebish
I noticed there was a few errors the first time I dumped it, I fixed a few manually but probably missed some.
I made a 2nd capture which should be fine (more checks), it's in my dropbox folder:
www.dropbox.com/sh/nrc4oppo121887l/AABQ_...IEn8A7BYvH5BpGa?dl=0
3010,30 3d 10 a9 ce ,12304,-50
Last edit: 15 Oct 2018 17:15 by goebish.
15 Oct 2018 19:15 #71368 by C0ckpitvue 777
I just flew it hard with the devo 10,no noticeable flaws in flight characteristics but if you enable channel 7 .flip channel,it's still misbehaving the same.
15 Oct 2018 19:32 #71369 by goebish
Updated, that should fix the issue with flip channel.
15 Oct 2018 20:56 #71370 by JayDrone
Replied by JayDrone on topic Bugs 3 mini
im willing to try it on the t8sg plus where can I find the dfu file to update the t8sg plus to have b3mini
15 Oct 2018 21:09 #71372 by goebish
15 Oct 2018 21:15 #71373 by JayDrone
any one have a vid on how to do that im not a novic but when it comes to that spreadsheet im a bit lost
15 Oct 2018 21:22 #71374 by JayDrone
i think i got most of it besides last steps a vid would be great
15 Oct 2018 21:23 - 15 Oct 2018 21:25 #71375 by goebish
Just follow the steps, you only have to find the line with your rxid in the green column then write down the number that's in the blue column.
... or just wait, the spreadsheet shouldn't be required anymore soon.
Last edit: 15 Oct 2018 21:25 by goebish.
15 Oct 2018 21:30 #71376 by goebish
if you can't edit your modelxx.ini file you can enter the number from the blue column in the protocol option dialog (Address), but it can be long if this is a large number ;)
15 Oct 2018 21:36 #71377 by JayDrone
apreciate ur time -- where do i find the protocol option dialog (Address) to enter the number into -
15 Oct 2018 21:39 #71378 by JayDrone
apreciate ur time -- where do i find the protocol option dialog (Address) to enter the number into - also im in no rush by any means bro - just figured if i ould get it bound i could test fly it -- if i cant figure it out again no rush at ll can wait till u guys have a more direct way of binding
15 Oct 2018 21:40 #71379 by C0ckpitvue 777
goebish wrote: Updated, that should fix the issue with flip channel.
Not that it matters to me,I can really do Without the flip channel but for the heads up,it still doesn't disable once enabled in a bind sequence...
15 Oct 2018 21:49 #71381 by goebish
JayDrone wrote: apreciate ur time -- where do i find the protocol option dialog (Address) to enter the number into -
In the same screen where you found the Rx id, by pressing ENT when the protocol name is highlighted.
15 Oct 2018 21:51 #71382 by JayDrone
the fixed id #??
15 Oct 2018 21:53 #71383 by goebish
C0ckpitvue 777 wrote: Not that it matters to me,I can really do Without the flip channel but for the heads up,it still doesn't disable once enabled in a bind sequence...
That's weird, but I suppose it also happens with stock Tx.
Just remember to arm with flip channel disabled ;)
15 Oct 2018 21:55 #71384 by goebish
JayDrone wrote: the fixed id #??
No, the "Rx Id" that's in the protocol option dialog ... That's the number you have to find in the spreadsheet, if you looked for the number in fixed id you got it wrong.
Time to create page: 1.164 seconds
