Bugs 3 mini
- C0ckpitvue 777
05 Oct 2018 22:29 #71192
by C0ckpitvue 777
Replied by C0ckpitvue 777 on topic Bugs 3 mini
You are the man Goebish,that was fairly quick...
- aszasza
05 Oct 2018 22:43 #71193
by aszasza
Replied by aszasza on topic Bugs 3 mini
I can capture a bind tomorrow as well if that helps.
- C0ckpitvue 777
06 Oct 2018 00:44 #71195
by C0ckpitvue 777
Yes it binds to my devo 10 and I also set channel 5 and it enables the led.
goebish wrote: Making some progress:
I'm not sure if it only works with my RX or with any bugs3 mini ... (ie is rxid used to compute 3 bytes of the xn297 address and the hopping sequence or not).
C0ckpitvue 777, here's a test build for Devo10, can you do as in the video and tell me if it binds ?
www.dropbox.com/sh/nrc4oppo121887l/AABQ_...IEn8A7BYvH5BpGa?dl=0
(led = channel 5, arming is not implemented for now, this is just a test)
- goebish
- NRF Weirdo
06 Oct 2018 06:40 - 06 Oct 2018 06:45 #71196
by goebish
Replied by goebish on topic Bugs 3 mini
@DPyro, Added test build for 7e.
Last edit: 06 Oct 2018 06:45 by goebish.
- goebish
- NRF Weirdo
06 Oct 2018 06:41 #71197
by goebish
Nice! I'm still not sure it works for any bugs3 mini as I wasn't able to complete the bind with DPyro IDs.
C0ckpitvue 777 wrote: Yes it binds to my devo 10 and I also set channel 5 and it enables the led.
- goebish
- NRF Weirdo
06 Oct 2018 06:45 - 06 Oct 2018 10:56 #71198
by goebish
Yes please, the more we have the better!
edit: I've tried with your ids / address (minus your rxid) / hopping sequence from the Bugs 3H thread but that doesn't work on my side, I got a reply from the quad but it doesn't complete the bind (same as with DPyro IDs).
I need DPyro to check if it works with the current hardcoded values.
aszasza wrote: I can capture a bind tomorrow as well if that helps.
Last edit: 06 Oct 2018 10:56 by goebish.
- C0ckpitvue 777
06 Oct 2018 13:27 #71199
by C0ckpitvue 777
I tried on my devo 7E,no good missing protocol message appears.
goebish wrote: @DPyro, Added test build for 7e.
- goebish
- NRF Weirdo
06 Oct 2018 13:42 #71200
by goebish
as often with my 7e builds ...
download the file again, it should be fixed (.mod file renamed)
- C0ckpitvue 777
06 Oct 2018 14:00 #71201
by C0ckpitvue 777
You are correct sir,I bound it to my 7E after re downloading file and channel 5 for lights,awesome job...
goebish wrote: as often with my 7e builds ...
- DPyro
07 Oct 2018 14:57 #71206
by DPyro
Replied by DPyro on topic Bugs 3 mini
Apparently I need to fix my controller as it's not detecting some of the protocols.
- C0ckpitvue 777
07 Oct 2018 15:18 #71207
by C0ckpitvue 777
Make sure the hardware ini file is edited
- aszasza
07 Oct 2018 15:55 #71208
by aszasza
Here is my bind. I'm not sure if it makes a difference, but this radio came with a bugs3h, but has no problem binding to the mini's board.
I'm a total noob btw, but I have a taranis x-lite with the 4in1 module. can someone point me to the right direction on how can I help testing?
- goebish
- NRF Weirdo
07 Oct 2018 15:57 #71209
by goebish
Pascal will port it to the 4-in-1 module once it's done, but it's not ready yet.
- DPyro
07 Oct 2018 16:50 #71210
by DPyro
Ah ya, been awhile since I've done this. Protocol shows up but not binding.C0ckpitvue 777 wrote: Make sure the hardware ini file is edited
- C0ckpitvue 777
07 Oct 2018 16:56 #71211
by C0ckpitvue 777
Did you update the dfu for that file?Also make sure you carry over the new protocol folder when transferring the files,make sure you put the bugs 3 mini model file in bind mode before plugging in the quad..
- goebish
- NRF Weirdo
07 Oct 2018 16:59 #71212
by goebish
What about other nrf24l01 protocols ? Are they working ?
DPyro wrote: Ah ya, been awhile since I've done this. Protocol shows up but not binding.
- DPyro
07 Oct 2018 17:21 #71213
by DPyro
I updated the dfu and copied the files over. All protocols show up.
- goebish
- NRF Weirdo
07 Oct 2018 17:27 #71214
by goebish
Can you select the Bug3Mini protocol and select bind or do you have an error ?
- DPyro
07 Oct 2018 19:14 - 07 Oct 2018 19:18 #71217
by DPyro
I selected bind, turned the quad on and then it went back to menu. RX ID changes from 0 to -29664
Last edit: 07 Oct 2018 19:18 by DPyro.
- C0ckpitvue 777
07 Oct 2018 19:39 #71218
by C0ckpitvue 777
It sounds like it's bound,are the quad leds solid?
Time to create page: 0.600 seconds
- Bugs 3 mini
