protocol for WL Heli V911-s
22 Dec 2018 04:52 #72099 by fin
Replied by fin on topic protocol for WL Heli V911-s
Thank you!
I can now fly V911S!
I'm really happy!
06 Apr 2019 02:38 #73711 by old4570
Replied by old4570 on topic protocol for WL Heli V911-s
I have a Jumper T8SG+ and can't get a bind on a V911s board I just got ..
Do I just need to download the latest build ? ( Deviation )
Currently V5.0.0-9d11a9c
08 Apr 2019 00:41 #73728 by old4570
I tried the latest nightly and no go .. ( No bind )
The firmware build was flaky though ...
Tx turning off for no reason for instance ... ( Not good )
19 Apr 2019 12:00 #74002 by goebish
Replied by goebish on topic protocol for WL Heli V911-s
@BirdBarber, @old4570, I converted the V911S protocol to use the CC2500 instead of the NRF24L01, that should fix your issues.
Test builds available here:
www.dropbox.com/sh/7k5f9f62ifucnd7/AACN4...pU_AMWWIKzdXOTa?dl=0
Please test & report :)
20 Apr 2019 12:17 #74030 by old4570
Will give it a go ASAP
20 Apr 2019 13:41 #74032 by dc59
Replied by dc59 on topic protocol for WL Heli V911-s
My t8sg v2 can't bind with V911S ........ FW: ee7176e
Tried Freq-Fine : -127 to +127 :(
20 Apr 2019 14:05 #74033 by demonogura
Replied by demonogura on topic protocol for WL Heli V911-s
I was able to bind and fly V911S with T8SG V2 PLUS rev.3.
Thank you very much.
20 Apr 2019 14:13 #74035 by goebish
demonogura wrote: I was able to bind and fly V911S with T8SG V2 PLUS rev.3.
With the test build ? (ee7176e)
20 Apr 2019 14:21 #74036 by demonogura
Test build deviation-t8sg_v2_plus-v5.0.0-ee7176e
Aileron,rudder reverse setting .
Thank you for the great work.
20 Apr 2019 14:23 - 20 Apr 2019 14:23 #74037 by goebish
Ok, thanks !
@dc59, can you try with a few different fixed IDs please ?
Does it work with nightly build ? (nrf24l01)
Last edit: 20 Apr 2019 14:23 by goebish.
20 Apr 2019 14:29 - 20 Apr 2019 20:31 #74038 by demonogura
With USB connection, FPVFreerider worked with WINDOWS 10 64bit without problems.
Others own H8-MINI,JJRC H8C、H8S-3D H20H、H98, X400, X600, X800, SYMA X5C-1
but confirmation 22 It will be a day.
H8C and H20H do not bind in [20190204 deviation-t8sg_v2_plus-v5.0.0-848faf5].
Last edit: 20 Apr 2019 20:31 by demonogura.
21 Apr 2019 01:55 #74050 by dc59
goebish wrote: Ok, thanks !
I download it from dropbox , which version number is correct?
21 Apr 2019 02:30 #74051 by dc59
I tried fixed ID=99999 , Freq-Fine=10-40(I set it to 25) and it works now!
I tried some different fixed IDs , the 99999 is the only one I can use till now.
FW: ee7176e from Dropbox
21 Apr 2019 06:14 #74052 by demonogura
fixed IDs=123456
Freq-Fine=-11~12(I set it to 0)
21 Apr 2019 09:42 - 21 Apr 2019 09:58 #74054 by goebish
dc59 wrote: I tried fixed ID=99999 , Freq-Fine=10-40(I set it to 25) and it works now!
That's interesting, does it work with nightly build and ID 123456 with your transmitter ?
(edit: also try nightly build with id 99999)
Last edit: 21 Apr 2019 09:58 by goebish.
21 Apr 2019 10:32 - 21 Apr 2019 10:35 #74056 by goebish
demonogura wrote: H8C and H20H do not bind in [20190204 deviation-t8sg_v2_plus-v5.0.0-848faf5].
H20H is supposed to use the H8-3D protocol with H20H format selected in protocol options. That's a 1 Mbps protocol, there's no reason it doesn't work except if they've changed the protocol.
I'm not sure the H8C is supported yet, it's not on my compatibility list (only H8C mini, not the same ...). Do you have a logic analyzer ?
Last edit: 21 Apr 2019 10:35 by goebish.
21 Apr 2019 10:44 #74057 by demonogura
Good evening, goebish.
Thank you for the advice of H20H.
I will try to bind test.
I also understood the case of H8C.
Unfortunately, I do not own the logic analyzer.
21 Apr 2019 11:59 #74061 by dc59
Fixed ID: 123456 / 888888 / 999999 these three ID can bind to my V911S with test build from dropbox,
but it can't bind with Apr. 20 nightly build (t8sg v2) , it seems not CC2500 protocol, I can't find Freq-Fine option,
and I can't find t8sg v2 FW in Apr. 21 nightly build.
21 Apr 2019 12:03 - 21 Apr 2019 12:04 #74062 by goebish
Ok, nightly build is still using nrf24, not the cc2500 (still experimental).
You mean the test build works with default ID 123456 now ? I though it didn't work
Last edit: 21 Apr 2019 12:04 by goebish.
21 Apr 2019 12:09 #74063 by goebish
Can you retry a few different arbitrary IDs now that you've found a working Fine-Freq range ?
Time to create page: 0.079 seconds
