Protocol for JJRC H56 on T8SG V2
- judicmr
- Topic Author
25 Jan 2019 15:53 #72527
by judicmr
Protocol for JJRC H56 on T8SG V2 was created by judicmr
Looking for a protocol for the JJRC H56 on the Jumper. It is also sold under the model TAAIW and Taichi
I've tried all the JJRC protocols, but none seemed to work.
- goebish
- I Void Warranties
26 Jan 2019 11:41 #72537
by goebish
Replied by goebish on topic Protocol for JJRC H56 on T8SG V2
Please send pictures of the inside of the transmitter so we can check which transceiver it's using.
- judicmr
- Topic Author
26 Jan 2019 17:11 #72543
by judicmr
Replied by judicmr on topic Protocol for JJRC H56 on T8SG V2
See transmitter guts. The IC markings appear to have been scrubbed off.
BTW - In addition to the JJRC protocols, I also tried the E010 and E011 ones.
Dumb question - I always remove the default fixed ID values (123456) prior to binding the first time. Is this the right thing to do for the first bind or could that be causing me problems?
- judicmr
- Topic Author
26 Jan 2019 17:12 #72544
by judicmr
- goebish
- I Void Warranties
26 Jan 2019 17:13 - 26 Jan 2019 17:15 #72545
by goebish
You can leave the ID as it is or change it, this has no importance.
I can't see your pictures, as you're a new user you might not to able to upload here, just use
imgur.com/
edit: Ok, no SPI bus here
What about the Quad ? Can you take a few pictures of the FC ?
Last edit: 26 Jan 2019 17:15 by goebish.
- judicmr
- Topic Author
26 Jan 2019 17:53 #72549
by judicmr
- goebish
- I Void Warranties
26 Jan 2019 19:32 #72555
by goebish
Can you try to read what's under the white blob ?
- judicmr
- Topic Author
26 Jan 2019 21:28 #72557
by judicmr
It looks like the IC under the white silicone has the following markings:
PAN159CY
1819AH
PAN159CY
1819AH
- goebish
- I Void Warranties
26 Jan 2019 21:36 #72558
by goebish
Ok, that means it's using a XN297 compatible transceiver.
It probably can be deviated, but dump "over the air" with an SDR device or arduino+nrf24 is necessary because there's no SPI bus here, that's not possible to use a logic analyzer.
If you want it to be deviated you'll probably have to send one to me or another dev ...
- goebish
- I Void Warranties
26 Jan 2019 21:39 #72559
by goebish
Anyway, have you tried every nrf24l01 protocols with every format options ?
It might be compatible with an existing protocol (unlikely, but that's worth a try ...)
- judicmr
- Topic Author
26 Jan 2019 22:29 #72560
by judicmr
I just tried those, but nothing worked.
I do appreciate the suggestions. Thanks.
- Moeder
09 Apr 2019 13:34 - 09 Apr 2019 15:35 #73746
by Moeder
Replied by Moeder on topic Protocol for JJRC H56 on T8SG V2
I will post you a deviation build to dump packet data, so we can maybe get some more info. What t8sg do you have? You can also try the build on the other drones you requested.
edit: please find attached builds for v2_plus and v2. Follow instructions from this post
Last edit: 09 Apr 2019 15:35 by Moeder. Reason: attached t8sg_v2 and v2_plus builds
Time to create page: 0.110 seconds
- Home
- Development
- Protocol Development
- Protocol for JJRC H56 on T8SG V2
