JJrc345 drones as gift in return for protocol.
12 Apr 2019 22:01 #73863 by Cdog31
Here is the packets shown at full throttle and no throttle.
12 Apr 2019 22:04 - 13 Apr 2019 11:02 #73864 by goebish
Ok, try my build, it should be fine.
There's something weird tho, can you tell when does the byte to the left of FF in the full throttle capture switch from 0A to 0E ?
(first number of the 2nd line) or maybe that's just a glitch of the picture due to slow lcd refresh rate.
Last edit: 13 Apr 2019 11:02 by goebish.
12 Apr 2019 22:08 #73865 by goebish
note that xn297 dump isn't included in my build (modular)
13 Apr 2019 05:55 #73868 by Moeder
While you are dumping again, you might as well check the other buttons for us. According to jjrc ads the drone features return to home, headless, lights flip and one button start and landing. All those features should be captured for us.
13 Apr 2019 07:04 #73869 by Cdog31
I will be happy to check the other buttons for you send the dumps soon. this drone has all of the buttons you mentioned except for the one button takeoff landing and LED control feature. It is a mistake in the advertisement. It does have headless, return to home, and the flip. I haven't had a chance to even try your test build because I just came home from work at 2 a.m. but I am excited to try I will do it shortly and also send the info on remaining buttons. Thank you for your help. Chris
16 Apr 2019 21:15 #73929 by Cdog31
This evening I will capture pictures of the remaining buttons. So that it is complete. I thank you for your patience and your time. Chris
16 Apr 2019 22:06 - 16 Apr 2019 22:08 #73930 by Cdog31
Here are the last three functions you need. Headless, return home, and flip.
Headless
Return home
Flipmode
That is the extent of the functionality. Please let me know if there's anything I can do to help you complete the test build. Thank you very much. Chris
Last edit: 16 Apr 2019 22:08 by Cdog31.
16 Apr 2019 22:08 #73931 by goebish
Thanks, can you try the test build please ?
16 Apr 2019 22:09 #73932 by Cdog31
Yes I am on my way to try the test build
16 Apr 2019 22:28 #73933 by goebish
I think your last 3 captures are wrong (no extra flags), you probably need to apply some throttle to enable those features.
16 Apr 2019 22:28 #73934 by Cdog31
I made a mistake on the three extra buttons. I did not reinitiate the scan. Here they are again correct.
Headless
Return home
Flipmode
16 Apr 2019 22:32 - 16 Apr 2019 22:33 #73935 by goebish
Ok good, seems the 0A -> 0E transition that I didn't understand is flip mode.
Try the test build, if it works I'll update it ;)
Last edit: 16 Apr 2019 22:33 by goebish.
16 Apr 2019 22:33 - 16 Apr 2019 22:40 #73936 by Cdog31
And yes it changes OE at full throttle.
Last edit: 16 Apr 2019 22:40 by goebish. Reason: oops, clicked the wrong button
16 Apr 2019 22:36 - 16 Apr 2019 22:41 #73937 by goebish
Cdog31 wrote: And yes it changes OE at full throttle.
Ok, you mean it's 0E only at full throttle (FF), nothing to do with flip mode ?
On the 2nd picture, seems throttle is full (FF) but the previous byte is 12, not 0E, is it only when RTH is enabled ?
Last edit: 16 Apr 2019 22:41 by goebish.
16 Apr 2019 22:44 #73938 by Cdog31
Yes OE. Only at full throttle nothing to do with RTH
16 Apr 2019 22:48 #73939 by Cdog31
I am trying my best to understand your questions. Should I test return to home, headless, and flip when at full throttle only
16 Apr 2019 22:51 #73940 by goebish
Just try the test build, I'll deal with the flags later.
16 Apr 2019 22:53 #73941 by Cdog31
Okay will report back shortly
16 Apr 2019 23:17 - 16 Apr 2019 23:18 #73943 by Cdog31
The drone binds. Response to throttle and elevator. However it flips on its own uncontrollably. I tried switches in each position. Still flips uncontrollably.
Last edit: 16 Apr 2019 23:18 by Cdog31.
16 Apr 2019 23:26 #73944 by goebish
NIce :)
I'll try to understand what's wrong and update the build.
Time to create page: 0.272 seconds
