JJrc345 drones as gift in return for protocol.
16 Apr 2019 23:52 #73945 by goebish
Test build updated, I spotted a mistake but I'm not sure that's what caused the flips.
17 Apr 2019 01:03 #73947 by Cdog31
Seems to be same results. Binds and takes off fine. Aileron seems to activate flip but also flips on its own.
17 Apr 2019 01:08 #73948 by Cdog31
I'm thinking about trying a model ini like E010 where channels 5 and 6 are already configured for flip and d/r. I'm not sure if that's related but I am trying to figure it out with what I can do. While I await your latesr response
17 Apr 2019 01:16 - 17 Apr 2019 01:17 #73949 by goebish
Only AETR are implemented for now, if it flips on its own that's a problem with the protocol, not your .ini, no worries.
Time to sleep here, but I'll fix the issue eventually ;)
Last edit: 17 Apr 2019 01:17 by goebish.
17 Apr 2019 01:25 #73951 by Cdog31
Thank you for your time
17 Apr 2019 16:35 - 17 Apr 2019 17:30 #73960 by goebish
So, I ran the JJRC345 protocol on a transmitter and xn297 dump on another one:
Seems this is quite similar to your stock Tx (the 02 is high rates)
AETR ranges are fine ... I'm not sure what's wrong.
Last edit: 17 Apr 2019 17:30 by goebish.
17 Apr 2019 16:41 - 17 Apr 2019 16:41 #73961 by goebish
Try this build, I removed the 02 flag, just in case:
www.dropbox.com/s/l5yzqid8pe68hxl/deviat...4a71_noflag.zip?dl=1
Last edit: 17 Apr 2019 16:41 by goebish.
17 Apr 2019 22:05 #73966 by Cdog31
Will try. Are there any dumps that I can redo that will help you so deep erratic flip. Please let me know I am willing.
17 Apr 2019 22:14 #73967 by goebish
Maybe a video could help, or just wait a bit, Moeder will add an option to dump packets to the filesystem, that should be easier than having to take pictures of the screen ;)
17 Apr 2019 22:28 #73968 by Cdog31
It sounds like a great option. I will try your test build soon. Thank you. Chris
17 Apr 2019 23:48 #73972 by Cdog31
I tried the latest build. The results remain the same. Channels respond correctly but erratic flipping still remains. I suspect this is fixable and will check back soon to see how I can help. Thank you. Chris
17 Apr 2019 23:50 - 17 Apr 2019 23:51 #73973 by goebish
Of course this is fixable :)
I'll make a few more test builds tomorrow. All you can do for now is testing.
Last edit: 17 Apr 2019 23:51 by goebish.
26 Apr 2019 20:43 #74150 by Moeder
Hi Chris,
attached is another special non-modular dumping build for your 7e (it doesn't contain goebish's protocol). It has the updated XN297DUMP protocol which will allow dumping to the file "datalog.bin" on the devo's filesystem. Since I made some changes to the interface here is the instructions on how to use it:
1. Choose a free model file for the dumping (already did that previously)
2. Go to protocol options, set "Bitrate" to 1 Mbps, "Address" to 5 byte and "Scrambled" to yes
3. Enter XN297 Dump in the Transmitter Menu
4. Bind the JJRC tx.
5. Set "Off" to "Scan" (Press right twice) and then press ENT to start scanning. It will stop scanning on a valid channel just as before
6. Now move the Mode selector from "Scan" to "Man" (press left once) and push ENT again. This will start recording.
7. Move each individual stick on the jjrx tx independently slowly from min to max. Make a little pause between the sticks. Also record the buttons just as you would use them with the quad (as in doing flips, setting different rates etc.) Please write down the order in which you recorded all the stick transitions and other states.
8. When finished, press ENT again on your devo, connect to the devo USB drive and copy the datalog.bin and paste its contents here or attach it together with the description of what you actually recorded in it (you will have to rename datalog to .txt or the forum won't allow uploading it).
Please note that recording space in datalog.bin is somewhat limited, so you might have to split it up in two sessions.
Looking forward to finishing the protocol work, please bear with us.
11 Jun 2020 15:40 #76452 by unknown
Hello, any updates? I have also basic MX5323 transmitter and would like use my DEVO 7E instead
17 Jun 2020 13:11 - 17 Jun 2020 13:14 #76491 by Stanek
Replied by Stanek on topic JJrc345 drones MX5323
this protocol uses a lot of toys.
Specifically, the micro car Velocis 1:32.
Pascal Langer has this hardware at his disposal and his statement was
"Looking over the air the TX transmits 3105 bits which is 389 bytes! There must be some correction encoding in place or special encoding which none of the components will emulate".
George
Last edit: 17 Jun 2020 13:14 by Stanek.
24 Jun 2020 19:27 #76519 by unknown
Replied by unknown on topic JJrc345 drones MX5323
Stanek wrote: Hi,
George
Yes, but anybody has SPI trace or dump? how to understand and emulate protocol?
24 Jun 2020 19:51 #76520 by Stanek
There is no trace, this transceiver contains an MCU inside the RF. Only data transmitted and captured by air. Anyone who owns a 2.4Ghz SDR can analyze this data.
24 Jun 2020 20:04 #76521 by unknown
Stanek wrote: Only data transmitted and captured by air. Anyone who owns a 2.4Ghz SDR can analyze this data.
For SDR you need some software decoder, its not so easy to analyze raw signals.
I see special firmware for DEVO7e above, us I understand it can help obtain dump or not?
24 Jun 2020 20:12 #76522 by Stanek
I've seen such a nice decoder at Goebish for XN297
https://github.com/goebish/XN297_dumper
24 Jun 2020 21:30 - 24 Jun 2020 21:34 #76523 by unknown
More easy way use Arduino + NRF24L01 + MULTI-Module code github.com/pascallanger/DIY-Multiprotoco...er/docs/Compiling.md
XN297 dumper mode included in firmware github.com/pascallanger/DIY-Multiprotoco...vanced_XN297Ldump.md
As I understand MX5323 chip has embedded XN297 radio.
Last edit: 24 Jun 2020 21:34 by unknown.
Time to create page: 0.059 seconds
