walkera deviation as joystick
- oskarra
- Topic Author
21 Feb 2022 11:47 #77850
by oskarra
walkera deviation as joystick was created by oskarra
hi , i use a walkera devo 8s with deviation tx 5.0 and i am trying to connect as joystick by usb, i dont know which parameter y have to change for use my RC as joystic and connect it by usb.thanks
21 Feb 2022 14:26 #77851
Replied by hexfet on topic walkera deviation as joystick
Select USBHID as the protocol on the model config page. Here's the description from the manual:
The USBHID protocol will convert he transmitter into a USB joystick. Connecting the transmitter to a PC via the USB cable will enable the transmitter to be detected as a joystick by the computer. This may be used to enable the transmitter to control any simulators that support joystick input. Some initial calibration may be necessary and is accomplished via the control panel applet of your operating system.
- gerhut
17 Aug 2023 21:43 #78299
by gerhut
Replied by gerhut on topic walkera deviation as joystick
I have a Devo7E and I updated everxthing to the latest Version.
When I connect Devo7E to PC with WIN11 it is online a USB Mass Storage but not a Joystick.
I also changed to USBHID.
What can I do?
Nicht e greetings Gerhard
What can I do?
- -=Hubi-Dirk=-
19 Aug 2023 06:26 #78300
by -=Hubi-Dirk=-
Replied by -=Hubi-Dirk=- on topic walkera deviation as joystick
Hi Gerhard,
have a look here at 7.3 USB: deviationtx.com/user-manual/user-manual-7e-10
Greetings
Dirk
Greetings
Dirk
- gerhut
26 Aug 2023 21:11 #78302
by gerhut
OK thanks. I rhink I hat to switch off and on the Transmitter. Now it works. Tankstelle a lot
- Home
- Development
- Protocol Development
- walkera deviation as joystick
