walkera deviation as joystick
21 Feb 2022 11:47 #77850 by oskarra
walkera deviation as joystick was created by oskarra
hi , i use a walkera devo 8s with deviation tx 5.0 and i am trying to connect as joystick by usb, i dont know which parameter y have to change for use my RC as joystic and connect it by usb.thanks
21 Feb 2022 14:26 #77851 by hexfet
Replied by hexfet on topic walkera deviation as joystick
Select USBHID as the protocol on the model config page. Here's the description from the manual:
The USBHID protocol will convert he transmitter into a USB joystick. Connecting the transmitter to a PC via the USB cable will enable the transmitter to be detected as a joystick by the computer. This may be used to enable the transmitter to control any simulators that support joystick input. Some initial calibration may be necessary and is accomplished via the control panel applet of your operating system.
17 Aug 2023 21:43 #78299 by gerhut
Replied by gerhut on topic walkera deviation as joystick
I have a Devo7E and I updated everxthing to the latest Version.
When I connect Devo7E to PC with WIN11 it is online a USB Mass Storage but not a Joystick.
I also changed to USBHID.
What can I do?
Nicht e greetings Gerhard
19 Aug 2023 06:26 #78300 by -=Hubi-Dirk=-
Replied by -=Hubi-Dirk=- on topic walkera deviation as joystick
Hi Gerhard,
have a look here at 7.3 USB: deviationtx.com/user-manual/user-manual-7e-10
Greetings
Dirk
26 Aug 2023 21:11 #78302 by gerhut
OK thanks. I rhink I hat to switch off and on the Transmitter. Now it works. Tankstelle a lot
Time to create page: 0.116 seconds
