Devo 10
04 May 2014 20:17 #22885 by Linga
Devo 10 was created by Linga
I want to reattach the Devo 10 v0.2/0.1 firmware, but the offer is only at Walkera.com v0.7/0.2 working incorrectly with QR Walkera X350.
Thanks.
04 May 2014 20:31 #22886 by PhracturedBlue
Replied by PhracturedBlue on topic Devo 10
I have 0.4A and 0.6A, but do not know where you would find 0.2. Maybe someone here has a copy.
14 May 2014 13:17 - 14 May 2014 13:21 #23226 by royalstar05
Replied by royalstar05 on topic Devo 10
I am looking to put back the origanal devention firmware back on my devo 10 (V0.7A/0.2) from walkera I got the 2 files from walkera I have been unable to get the lib. file to load
please help I need step by step
thank you
Last edit: 14 May 2014 13:21 by royalstar05. Reason: add info
05 Jul 2014 15:39 #24401 by Sputnik
Replied by Sputnik on topic Devo 10
Same problem
need help
06 Jul 2014 13:32 #24415 by PhracturedBlue
Make sure you have the latest dfuse software from walkera
Unzip the walkera firmware zip file. If you already have done this, delete the files you unzipped and do it again! Really. It is important.
Start the Dfuse application
turn on your Tx while holding 'Ent' to put it into programming mode.
Select the 'Firmware' tab (should already be selected)
Select ...
Select the firmware dfu (should have 'Fw' in its name I think
press 'Upgrade'
when it is finished, select the 'Library' tab
Select '...' on 'Upgrade or Verify File' (DO NOT use the 'Upload File' box!!!)
select the library dfu (shoul have 'Lib' in its name I think)
press 'Upgrade'
you are now done
06 Jul 2014 14:19 #24419 by Sputnik
Done all
walkera on 1.2
devo 10 on 4.0.1
after that binding is okay, but commands non except on trotl gimbl move camera up and down
any other command is not working
06 Jul 2014 16:47 - 07 Jul 2014 05:15 #24428 by Sputnik
Last edit: 07 Jul 2014 05:15 by Sputnik.
06 Jul 2014 21:45 #24445 by FDR
Replied by FDR on topic Devo 10
I've already told you, that this config is totally wrong.
It's for CP helicopters, not for quads...
You shouldn't pollute the whole forum with your question.
08 Jul 2014 19:24 #24471 by Sputnik
For what is upload option on dfuse?
09 Jul 2014 03:15 #24480 by vlad_vy
Replied by vlad_vy on topic Devo 10
It's usable for save models config only.
15 Jul 2014 03:18 #24585 by Plamen
Replied by Plamen on topic Devo 10
I've seen this a couple of times ... so what happens if one accidentally DOES use the "Upload File" box?
Time to create page: 0.036 seconds
