Devo 10
- Linga
- royalstar05
14 May 2014 13:17 - 14 May 2014 13:21 #23226
by royalstar05
Replied by royalstar05 on topic Devo 10
I am looking to put back the origanal devention firmware back on my devo 10 (V0.7A/0.2) from walkera I got the 2 files from walkera I have been unable to get the lib. file to load
please help I need step by step
thank you
thank you
Last edit: 14 May 2014 13:21 by royalstar05. Reason: add info
- Sputnik
06 Jul 2014 13:32 #24415
Replied by PhracturedBlue on topic Devo 10
Make sure you have the latest dfuse software from walkera
Unzip the walkera firmware zip file. If you already have done this, delete the files you unzipped and do it again! Really. It is important.
Start the Dfuse application
turn on your Tx while holding 'Ent' to put it into programming mode.
Select the 'Firmware' tab (should already be selected)
Select ...
Select the firmware dfu (should have 'Fw' in its name I think
press 'Upgrade'
when it is finished, select the 'Library' tab
Select '...' on 'Upgrade or Verify File' (DO NOT use the 'Upload File' box!!!)
select the library dfu (shoul have 'Lib' in its name I think)
press 'Upgrade'
you are now done
Select ...
press 'Upgrade'
press 'Upgrade'
you are now done
- Sputnik
- Sputnik
- Sputnik
Time to create page: 0.406 seconds
Stock Firmware Help
- Devo 10
