Alexandre
22 Feb 2019 22:58 #72976 by xandao
Alexandre was created by xandao
Can anyone tell me what the correct firmware of the T8SG lite jumper is? I made an update, now the radio is without Bind's option. In place is written: Re-int.
What does that mean?
23 Feb 2019 01:24 #72977 by gdenton
Replied by gdenton on topic Alexandre
That is covered in the User Manual:
Bind/Re-Init: Depending on the protocol and Fixed-ID setting, the transmitter may bind with the model on start-up, or may need to be manually bound once. See Protocols for more on specific protocols. If the protocol does not support binding, the button will show ‘Re-Init’, which can be used to switch protocols without power-cycling the transmitter.
24 Feb 2019 22:15 #73002 by xandao
Replied by xandao on topic Alexandre
and when the display letters are backwards and forwards?
with the message: Missing Modules: CYRF6836
25 Feb 2019 06:14 #73006 by vlad_vy
Replied by vlad_vy on topic Alexandre
I think "T8SG Light" will work with "t8sg_v2" firmware.
With changed "hardware.ini":
;enable-haptic=1
;switch_types: 3x4, 3x3, 3x2, 3x1, 2x8, 2x7, 2x6, 2x5, 2x4, 2x3, 2x2, 2x1, potx2, potx1
;Add nostock if stock FMOD and HOLD switches have been removed.
  extra-switches = nostock
  extra-switches = 3x4
; extra-switches = 2x2
  extra-switches = potx2
;extra-buttons=
[modules]
  enable-cyrf6936 = 0
; has_pa-cyrf6936 = 1
; enable-a7105    = A13
; has_pa-a7105    = 1
  enable-cc2500   = A14
  has_pa-cc2500   = 1
; enable-nrf24l01 = A15
; has_pa-nrf24l01 = 1
; enable-multimod = A13
04 Mar 2019 13:30 #73197 by xandao
Good morning, I used this firmware, but now the right joystick is not working and the letters on the display are upside down ... you know what you do in that case?
09 Mar 2019 16:45 #73287 by xandao
do you have to share the TX file too?
Time to create page: 0.031 seconds
