Alexandre
- xandao
- gdenton
23 Feb 2019 01:24 #72977
by gdenton
Replied by gdenton on topic Alexandre
That is covered in the User Manual:
Bind/Re-Init: Depending on the protocol and Fixed-ID setting, the transmitter may bind with the model on start-up, or may need to be manually bound once. See Protocols for more on specific protocols. If the protocol does not support binding, the button will show ‘Re-Init’, which can be used to switch protocols without power-cycling the transmitter.
- xandao
25 Feb 2019 06:14 #73006
Replied by vlad_vy on topic Alexandre
I think "T8SG Light" will work with "t8sg_v2" firmware.
With changed "hardware.ini":
;enable-haptic=1
;switch_types: 3x4, 3x3, 3x2, 3x1, 2x8, 2x7, 2x6, 2x5, 2x4, 2x3, 2x2, 2x1, potx2, potx1
;Add nostock if stock FMOD and HOLD switches have been removed.
extra-switches = nostock
extra-switches = 3x4
; extra-switches = 2x2
extra-switches = potx2
;extra-buttons=
[modules]
enable-cyrf6936 = 0
; has_pa-cyrf6936 = 1
; enable-a7105 = A13
; has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
; enable-nrf24l01 = A15
; has_pa-nrf24l01 = 1
; enable-multimod = A13- xandao
Time to create page: 0.705 seconds
Stock Firmware Help
- Alexandre
