Devo 6/8 models work in the Devo 10?
- Tom Z
25 Nov 2012 00:57 #3133
by Tom Z
Devo 6/8 models work in the Devo 10? was created by Tom Z
Will the deviation devo 6/8 models work in the deviation devo 10?
And what about vice versa?
Models have the same names in both TX's (model4 for example). Would I just
need to over-right the .ini model from the Devo 6/8 to the Devo 10 and vice versa?
I am getting ready to make some deviation models using the settings from my TX Setup Guide Sticky on rcgroups.
Tom
Tom
25 Nov 2012 01:07 #3134
Replied by PhracturedBlue on topic Devo 6/8 models work in the Devo 10?
Yes models are fully compatible in both directions.
If you use the Aux inputs in the Devo10, they will be dropped when going to the Devo8 (I may fix that in the future in a similar way to how the Devo8/10 models downgrade to Devo6)
- Tom Z
25 Nov 2012 02:26 #3136
by Tom Z
Replied by Tom Z on topic Devo 6/8 models work in the Devo 10?
Thanks, that is great they are fully compatible in both directions.
I am using your devo10-alpha0.2
Is it OK to make models for people now or should I wait until you release
the final version?
If not I have your emulator I can make some models on for now.
I have a few questions.
1. Is the Telemtry working on the Devo beta? I can't get it to work.
2. Is there pitch hold in the deviation firmware? I found the throttle hold but not pitch hold.
3. Icon on right hand side on home screen is all black dots. Do I need to do something to get an icon in that spot?
Tom
the final version?
Tom
25 Nov 2012 03:17 #3138
If you are not building from source, you should wait until a release to ensure you have the latest features. The release is (I think) only a couple of days away.
- suvsuv
25 Nov 2012 03:17 #3139
by suvsuv
Replied by suvsuv on topic Devo 6/8 models work in the Devo 10?
Forget the alpha0.2, which is outdated for a long time, you should use the latest beta version.
To setup pit hold , you can setup a complex template with 4 pages for the Ch6. In the 4th page, you just set up a curve and set its switch to RUD DR
- Tom Z
25 Nov 2012 05:24 #3142
by Tom Z
That version is much better!
The fonts are nice and there are a lot more menus and features.
Also there is now an icon on the home page instead of the black dot square.
I got the pitch hold working with your instructions.
Still can't get the Telemetry working but I'll keep playing around with it.
Thanks for helping out.
Tom
Tom
Time to create page: 0.277 seconds
- Devo 6/8 models work in the Devo 10?
