Phoenix problems in PRE 2.1
- HiNote
16 Dec 2012 00:31 #4023
by HiNote
Phoenix problems in PRE 2.1 was created by HiNote
i have problems with this version.
It can't work with phoenixrc for me.
With latest installed version (deviation-devo6-f75fc49368fe), it works ok, but with this version, my devo 6s is detected by phoenix as connected, but no channel moves in phoenixrc
I tried to configure a new trasmitter, but the same problem again. Nothing moves in phoenix.
I didn´t change values in PPM settings. 8ch selected
- Hexperience
16 Dec 2012 02:09 - 16 Dec 2012 02:42 #4024
by Hexperience
Replied by Hexperience on topic Phoenix problems in PRE 2.1
Confirmed. Same here.
Last edit: 16 Dec 2012 02:42 by Hexperience.
16 Dec 2012 05:17 #4025
Replied by PhracturedBlue on topic Phoenix problems in PRE 2.1
try selecting ppm options(click the 'PPM' string). Make sure the frame size is 22500.
If you had a previous version that had some options, it won't upgrade properly, but upgrading from a 2.0 model or creating a new model, or selecting the protocol options should all fix the issue.
I do not guarantee seamless upgrades from intermediate hg builds.
- dado099
16 Dec 2012 09:07 - 16 Dec 2012 09:08 #4028
by dado099
Replied by dado099 on topic Phoenix problems in PRE 2.1
I confirm, also creating a new model, no ppm signal output at all.
My usb interface always blinks when receiving a ppm signal, but now it's steady.
Hope for a fix.
Thank you
Hope for a fix.
Thank you
Last edit: 16 Dec 2012 09:08 by dado099.
16 Dec 2012 09:30 #4030
Replied by vlad_vy on topic Phoenix problems in PRE 2.1
Definitely, there is a bug at PPM protocol. With Reflex simulator PPM works only at 10 channel mode. All other modes = no response. Simulator detect number of channels, but used channels have random numbers and not respond to sticks, not used channels have 0 values.
- sbstnp
16 Dec 2012 11:01 #4031
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Replied by sbstnp on topic Phoenix problems in PRE 2.1
My PPM setup is default:
Center PW= 1100
Notch & Delta = 400
Frame size = 22500
Phoenix works and detects the TX only in 10 channel mode. I had to recalibrate the sim since all the channels were way off. After this everything works as it did before.
Center PW= 1100
Notch & Delta = 400
Frame size = 22500
Devo 10 + 4in1
16 Dec 2012 11:38 - 16 Dec 2012 11:39 #4032
ppmout.c
if(state & 0x01) {
val = pulses[state / 2]; => pulses[0.5] or pulses[1.5] or ...
if(state & 0x01) {
Last edit: 16 Dec 2012 11:39 by vlad_vy.
16 Dec 2012 12:37 - 16 Dec 2012 12:38 #4033
static u16 ppmout_cb()
static volatile u16 accum;
u16 val;
if (state == 0) {
accum = 0;
build_data_pkt();
if(state & 0x01) {
PWM_Set(1);
if(state == num_channels * 2 + 1) {
state = 0;
if (num_channels > 9)
return num_channels > 9
? Model.proto_opts[PERIOD_PW] + (num_channels - 9) * 2000 - accum
: Model.proto_opts[PERIOD_PW] - accum;
val = pulses[state / 2]; maybe val = pulses[(state - 1) / 2];
} else {
PWM_Set(0);
val = Model.proto_opts[NOTCH_PW];
state++;
accum += val;
return val;
It's working for any number of channels.
u16 val;
if (state == 0) {
accum = 0;
build_data_pkt();
if(state & 0x01) {
PWM_Set(1);
state = 0;
} else {
PWM_Set(0);
state++;
accum += val;
return val;
Last edit: 16 Dec 2012 12:38 by vlad_vy.
- Hexperience
16 Dec 2012 13:06 #4034
by Hexperience
Yeah, I fixed mine like this...
return Model.proto_opts[PERIOD_PW] + (num_channels - 9) * 2000 - accum;
return Model.proto_opts[PERIOD_PW] - accum;
But I could be wrong so I didn't say anything.
16 Dec 2012 13:16 #4035
It's incorrect.
if (num_channels > 9){
else{
or will be the same
else{
or will be the same
16 Dec 2012 13:18 #4036
should be fixed now.
- Hexperience
16 Dec 2012 13:39 - 16 Dec 2012 13:40 #4039
by Hexperience
Without the brackets the way I did it works fine. One line if statement...
Anyway.. that's exactly why I didn't say anything...
vlad_vy wrote: It's incorrect.
Last edit: 16 Dec 2012 13:40 by Hexperience.
16 Dec 2012 13:43 #4040
Yes, it will work, but difficult to read.
Time to create page: 0.121 seconds
- Phoenix problems in PRE 2.1
