newbie question on porting existing config
01 Jan 2013 13:07 #4469 by ckl
how can you port the existing configs(trex 250, 500, xyz, rx801) after convert?
thx,
01 Jan 2013 15:00 #4476 by RandMental
Replied by RandMental on topic newbie question on porting existing config
I assume you mean transfering an existing Walkera Devo8s model/setup to a DeViation model?
I don't believe you can port or translate them directly to the Deviation, the model designs and model files are not compatible, alhtough you can obviously get the same end result.
I made a note of my original set-ups and reconfigured it on Deviation.
01 Jan 2013 15:05 #4477 by FDR
If you mean you have DEVO 8 configs, than it's not possible to convert them, however my model configurator webapp ( rc.fdr.hu/model.php ) can help you to view all your changes in them...
04 Jan 2013 20:20 #4676 by ckl
thx, FDR and RandMental. I will try the webapp.
05 Jan 2013 01:56 #4681 by Hexperience
Replied by Hexperience on topic newbie question on porting existing config
FDR, does your web app read walkera model configs? I see we can upload to it.
05 Jan 2013 08:51 #4686 by FDR
Yes, but only DEVO 8/8S are supported...
Time to create page: 1.394 seconds
