walkera 2601 protocol - new problem with 2.1
11 Jan 2013 12:33 #4924 by NotFastEnuf
I know the 2601 protocol is the most hated of the codes but a new problem has developed after my 2.1 install. Using both 5+1 and 6+1, the ch3 throttle output is causing the rudder servo to move as if it is mixed to throttle. This does not show as motion on a bar graph for channel outputs but the rudder servo does move when moving the throttle stick. I can work around this by setting the throttle mixer to none and using ch 6 or 7 mixer to assign source to throttle. I did not have this problem in any previous deviation builds.
  • rbe2012
  • rbe2012's Avatar
11 Jan 2013 12:45 #4925 by rbe2012
Replied by rbe2012 on topic walkera 2601 protocol - new problem with 2.1
You wrote you did not have this problem before. Did you use the same config? Or may it be possible that there is some torque compensation in the rx? I found the Walkera rx which are produced more or less for one model (esp. for fbl) having some functions implemented which are not controllable by the tx. This might be one.
11 Jan 2013 14:59 #4927 by NotFastEnuf
Replied by NotFastEnuf on topic walkera 2601 protocol - new problem with 2.1
No it has to be in the 2.1 build. I did not have this problem with 1.8 or 2.0 builds. I did a reformat after the dfu upgrade and only copied in old model files.
12 Jan 2013 14:15 #4943 by PhracturedBlue
Replied by PhracturedBlue on topic walkera 2601 protocol - new problem with 2.1
The 2601 protocol is terrible.
I think I forgot to zero out the thr<->Rudder mix which explains this behavior. File a ticket on bitbucket and I'll look into it.
12 Jan 2013 19:12 #4947 by NotFastEnuf
That's what I was thinking too PB. I will post on bitbucket this weekend. Thanks again for your hard work. I used to forget to zero out the same mix on my 2602 tx all the time. Other than that my 2601 protocol has logged hundreds of hours now and is performing flawlessly!
Time to create page: 1.103 seconds
