Complex mix and Mux ???
19 Jan 2013 10:23 - 19 Jan 2013 10:26 #5181 by vlad_vy
Complex mix and Mux ??? was created by vlad_vy
What doing complex mix if it first or single? Except Mux:'replace'.
1) Mux: 'mult' = do nothing = output always 0% (trim works at range -10% - +10%)
2) Mux: 'add' = do nothing = output always 327% or -327% (trim at some point will slow change output from 327% to -327%)
3) Mux: 'max' = do nothing = output always 0% (trim from 0 point will slow change output from 0 to +327% or to -10%)
4) Mux: 'min' = do nothing = output always 0% (trim from 0 point will slow change output from 0 to -327% or to +10%)
Is it normal?
Last edit: 19 Jan 2013 10:26 by vlad_vy.
19 Jan 2013 10:29 #5182 by domcars0
Replied by domcars0 on topic Complex mix and Mux ???
If you say that single or first mux operator can only be 'replace', I think you're right.
19 Jan 2013 10:53 - 19 Jan 2013 11:03 #5184 by vlad_vy
Replied by vlad_vy on topic Complex mix and Mux ???
Cx = if(Mo.Mux == 'mult') {1} else {0} ...
Last edit: 19 Jan 2013 11:03 by vlad_vy.
19 Jan 2013 11:17 - 19 Jan 2013 11:19 #5186 by domcars0
Unfortunatly (but reasonably) for the first mix I think that the algorythm consider that C_(x-1) = 0 (where C_(x-1) is the value of the previous output)
So
Cx = if(Mo.Mux == 'mult') {1} else {0} * C_(x-1) = 0
Last edit: 19 Jan 2013 11:19 by domcars0.
Time to create page: 0.603 seconds
