DEVO10 "ENT" button issue
- dc59
25 Jan 2013 05:37 - 27 Jan 2013 09:20 #5497
by dc59
DEVO10 "ENT" button issue was created by dc59
Hi PB,
Please check it out:
This is my friend's DEVO10,even he has already upgraded to newest FW,but it still happened sometimes,is that a button problem?
it's looks like "ENT" was pressed twice...
Thanks.
Thanks.
Last edit: 27 Jan 2013 09:20 by dc59.
- sbstnp
25 Jan 2013 08:00 #5499
by sbstnp
Oversensitive button. Try pressing it with a lighter pressure, or on a corner.
Could be fixed in the firmware with a delay between actions most probably.
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Replied by sbstnp on topic DEVO10 "ENT" buttom issue
dc59 wrote: This is my friend's DEVO10,even he has already upgraded to newest FW,but it still happened sometimes,is that a buttom problem?
Thanks.
Devo 10 + 4in1
25 Jan 2013 13:32 - 25 Jan 2013 13:45 #5502
Replied by PhracturedBlue on topic DEVO10 "ENT" buttom issue
we don't do any debounce in deviation. but we probably should. there is also some issue with button handling in general, as per another ticket. I'm not sure if this is the same issue or not though. If you want to get tickets fixed, file them on bitbucket. it is effectively my todo list, and the best way to make sure I don't forget them.
Edit: I think I told you to post the issue here, but I meant bitbucket where we keep issues:
bitbucket.org/PhracturedBlue/deviation/i...atus=new&status=open
Last edit: 25 Jan 2013 13:45 by PhracturedBlue.
- dc59
25 Jan 2013 13:58 #5504
by dc59
Sorry PB I post it in wrong place ~~~
(I found this problem happened on 7E!)
Replied by dc59 on topic DEVO10 "ENT" buttom issue
PhracturedBlue wrote: we don't do any debounce in deviation. but we probably should. there is also some issue with button handling in general, as per another ticket. I'm not sure if this is the same issue or not though. If you want to get tickets fixed, file them on bitbucket. it is effectively my todo list, and the best way to make sure I don't forget them.
06 Feb 2013 02:34 #6071
I checked in a fix to add debounce which should resolve this issue.
Time to create page: 0.387 seconds
- DEVO10 "ENT" button issue
