Setting channel safety to more than -100/+100
30 Jan 2013 09:42 - 30 Jan 2013 09:46 #5775 by cruncher
How can I set the channel safety value to be more than -100 (or make it scale together with the limits)?
For example, I have scale for the throttle channel set to +130/-130 (this is required for my setup). When I enable safety switch for this channel to be on the throttle hold switch, I cannot set safety to move beyond -100. Is this a workaround for this? I need to be able to set safety value to match my lowest limit, otherwise safety won't work since FBL unit does not see the calibrated zero (which is -130).
Last edit: 30 Jan 2013 09:46 by cruncher.
30 Jan 2013 10:03 - 30 Jan 2013 10:04 #5777 by FDR
Then instead of the safety value you should use a plus complex mixer page for the throttle hold on the throttle channel.
If there you set a "fixed" function with value of -100, then the channel scale will make it -130 in the end...
Last edit: 30 Jan 2013 10:04 by FDR.
30 Jan 2013 10:04 - 30 Jan 2013 10:05 #5778 by sbstnp
cruncher wrote: How can I set the channel safety value to be more than -100 (or make it scale together with the limits)?
This is a bug, there is a commit fixing this but I don't think it made it in 2.1.0 or 2.1.1
bitbucket.org/PhracturedBlue/deviation/c...6696d09f5686200519c6
Your choices are:
1. Use a experimental build
2. Wait for another release
You can find builds here, or you can build your own using my Linux VM or RugWarrior's Windows environment.
Or you can ask for one, I'll gladly help, just tell me your TX.
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Last edit: 30 Jan 2013 10:05 by sbstnp. Reason: Or use FDR's method :)
30 Jan 2013 10:06 #5779 by cruncher
Replied by cruncher on topic Setting channel safety to more than -100/+100
Thanks all, didn't realise somebody has already reported this... I'll use complex mixer for now, don't want to risk it with experimental release - I'm flying trex 450 and 600 with my Devo8s.
Time to create page: 0.110 seconds
