Removing shield and diode 7E for better reach
13 Feb 2015 06:32 #28624 by karl007
Replied by karl007 on topic Removing shield and diode 7E for better reach
Hey guys, thanks for your help.
Unter the solder is a thin (not thin enought) copper core of a wire.
I took a MM and messured from my soldered short to another endpoint, so I get shure there are a connection (no cold solder). Right?
I would say, that my messurements told me that there are a connection and it should work. But please correct me.
A: 600 Ohm (displays 0.600 with MM setting 2kOhm)
B: 0.06 Ohm (displays 0.06 wit MM setting 200Ohm)
(add the MM setting, cause not 100% shure about the conversion)
Is there a indicator how i can verify if it works?
I tried without the shield in the lowest setting and get a range about 5-10cm.
What range should it be? 1m? 10m?
The last think I would try, is to resolder my short and tried with a isolated wire and only
solder the two ends, to exclude the possibility to short a trace below.
13 Feb 2015 11:13 #28627 by aMax
...yellow = new bridge
...blue = measured points = 0 ohms
Attachment not found
13 Feb 2015 11:26 #28628 by karl007
thanks aMax for your quick response.
just to make shure i do it right ;)
aMax wrote: ...yellow = new bridge
new bridge after remove my old solder?
aMax wrote: ...blue = measured points = 0 ohms
messure points after solder the new bridge, to check if it works?
13 Feb 2015 11:42 - 13 Feb 2015 12:17 #28629 by aMax
Please check blue first.... just to know, if there was a short or not.
Yellow is the allowed bridge...., but if you are able, take the bottom pad of the removed diode.
Edit: You only will find one connection with 0 Ohms, I don´t know to which pad the trace goes, but I think to the left.
Added a picture of the PACTL lines.
Last edit: 13 Feb 2015 12:17 by aMax. Reason: picture added
13 Feb 2015 17:05 #28635 by karl007
aMax wrote: Please check blue first.... just to know, if there was a short or not.
Both pins got 0.6 Ohm.. So there is an unwanted short to the trace below, right?
15 Feb 2015 13:17 #28720 by karl007
Ok, I removed my soldered short and get the same messurements (0.6 Ohm for both blue lines).
So the trace below are OK.
Then I add a wire along your yellow line and now it worked.
Thanks for being so patient and helpfull to me !!
Promise, I never solder smd anymore! ;)
15 Feb 2015 14:12 #28723 by aMax
Nice to hear..
What is your result now with range test at 100uW?
27 May 2015 17:45 #33064 by Jerm357
Replied by Jerm357 on topic Removing shield and diode 7E for better reach
Since so many have done this mod, can someone please tell me if the voltage fluctuating on the LCD screen is normal after its done?
When using the cyrf6936 module, at the lowest power of 100uw, the battery voltage was between 5.10 and 5.12 jumping back and forth. With the full power of 150mw, the voltage fluctuates between like 5.06 and 5.10. The A7105 module is unaffected and is acting the same as it was before the mod. This all make sense and I think is working like it should since Im asking more power from the cyrf6936 module now, but I just want to make sure this is happening to everyone who did the mod.
27 May 2015 19:53 - 27 May 2015 20:03 #33069 by aMax
Yes, seem to be normal, max 0.06 V at 100/150mW.
At 100uW up to 30 mW, you will not notice it, no oscillating at my 7e,
The next difference is telemetry on/off at full power.
With Devo little less than with DSMX. Don't know why....... :huh:
Last edit: 27 May 2015 20:03 by aMax.
27 May 2015 20:42 #33075 by Jerm357
Ok, cool. Just to make sure, heres a video of what mines doing at full power. Does your voltage do the same?
31 May 2015 22:34 #33296 by mstrghettorigg
Replied by mstrghettorigg on topic Removing shield and diode 7E for better reach
So I tried this mod and it looks like the 10k resistor is missing. (One in violet on page 2)
I'm pretty sure I didn't remove this and as far as I know it is a new unit.
I can't seem to get the range to increase. I left the diode on and jumpered the two side together.
I changed it to enable by taking the semicolong out of "has_pa-cyrf6936 = 1"
I did not take the semicolon out of "; enable-cyrf6936 = B12" (I tried both ways)
So I'm not sure if it's just the missing 10k that's causing the issue. Has anyone had an unit with missing resistors?
any help would be appreciated.
31 May 2015 23:58 #33300 by PhracturedBlue
Replied by PhracturedBlue on topic Removing shield and diode 7E for better reach
If you take a picture it may help identify what is going on.
01 Jun 2015 04:04 - 01 Jun 2015 04:09 #33304 by mstrghettorigg
Thanks for the feedback.
I tried taking it earlier and I couldn't zoom in enough, but i used a loupe and I got it hopefully good enough for you guys to see what's going on.
Please let me know if you have any ideas.
Last edit: 01 Jun 2015 04:09 by mstrghettorigg.
01 Jun 2015 04:09 #33306 by mstrghettorigg
OK. I must be dumb because I can't figure out how to attach an image...
01 Jun 2015 04:10 #33307 by PhracturedBlue
make sure it is no more than 1MB or just attach a link.
01 Jun 2015 04:13 - 01 Jun 2015 04:16 #33308 by mstrghettorigg
Let's see if this works.
So it's the resistor below the diode I jumped is missing and I believe this is the 10K that was mentioned earlier.
Last edit: 01 Jun 2015 04:16 by mstrghettorigg.
01 Jun 2015 04:52 #33309 by PhracturedBlue
What color was the device you removed and replaced with a jumper? was it black, or a yellow/white color? I haven't looked at the internals of a 7e for a couple years, and I don;t remember the circuit layout, so I am unsure what the missing resistor in your image is for. There is an indication that they may have changed the board components recently, and if so , the diode mod may not be the proper solution. I would need to see a 'pre modified' transmitter to assess.
01 Jun 2015 04:58 #33310 by mstrghettorigg
The part is black and I did not remove them. I just jumped both sides with the wire with the black part intact.
The resistance is reading 0 when I probe both side.
Other than that the image is pre modified. I'm sure it's probably very hard to see anything with that image though.
Please let me know if you have any ideas on what I can try.
01 Jun 2015 12:09 - 01 Jun 2015 12:14 #33314 by aMax
PhracturedBlue wrote: What color was the device you removed and replaced with a jumper? may not be the proper solution. I ..........
Have a look at ..
www.deviationtx.com/forum/3-feedback-que...each?start=120#28384
...the reading is 12.2k at both directions.
I messured the removed part.
Edit: Don't care about the yellow square...., the part is right besides.
Last edit: 01 Jun 2015 12:14 by aMax.
01 Jun 2015 12:36 #33315 by mstrghettorigg
Hi aMax,
Are you saying that I need to add a 12.2k ohm resistor at the missing area on my picture?
Please confirm.
Time to create page: 0.707 seconds
