Standard Mixer Take-2
24 Feb 2013 07:11 #6929 by PhracturedBlue
Replied by PhracturedBlue on topic Standard Mixer Take-2
did you replace the heli_std template? You need the most recent one to not get the invalid ini message.
24 Feb 2013 07:12 #6930 by PhracturedBlue
and reset sw is removed from std gui timer page. It didn't make any sense with the limited switch options.
24 Feb 2013 07:26 #6931 by vlad_vy
Replied by vlad_vy on topic Standard Mixer Take-2
Sorry. I'm forgot replace template folder. Now it works.
25 Feb 2013 05:14 #7011 by vlad_vy
Why we need Std GUI 'D/R & Expo' up to 125%, what incorrectly translated to Advanced GUI 'Expo&D/R' 100%, if we have 'Travel adjust' up to 175%, what correctly translated to channel scale 175%???
25 Feb 2013 05:22 #7012 by PhracturedBlue
the problem is that the travel-adjust is set at the channel output whereas the scale is set at the mixer. You also have cyclic mixing thrown in. So setting the scale on the mixer is far easier, but it adds risk to allow it on the advanced mixer. I am not yet sure how I want to proceed on this one.
25 Feb 2013 14:31 #7027 by vlad_vy
Maybe as usual? Channel scale (travel adj) up to 150%, channel limit (limit adj) up to 150% and mixer scale (D/R) up to 125%.
25 Feb 2013 18:21 #7043 by coaster
Replied by coaster on topic Standard Mixer Take-2
Hi all
i am a little bit confused, if i change the travel +-130 %
in the travel adjust menu for a channel, must the scale in the
DR mixer also changed to 130% ?
cheers
Graziano
25 Feb 2013 19:41 #7045 by domcars0
Replied by domcars0 on topic Standard Mixer Take-2
coaster wrote: Hi all
cheers
Graziano
Hi travel adjust is relatif to servo, not to mixer...
25 Feb 2013 19:50 #7046 by coaster
Hi domcars0,
that means the 100% in the DR menu correspond
to the value (130%) in the travel adjust ?
cheers
Graziano
25 Feb 2013 22:49 #7056 by domcars0
Aïe...It's more complicated :(
Travel Adj is the Travel of a servo .... while DR depend of many other things: the mixer on which it's applied, the swashplate type (120,90...), the curves if any etc...
Sorry as my english is very bad, I hope somebody else will be able to clarify this.
26 Feb 2013 02:44 #7059 by gapi
Replied by gapi on topic Standard Mixer Take-2
Gosh! Just when I am clicking on how to configure in the Advanced mode this Standard mode gets it together. Funny!
I just configured my Master CP VIA both ways and really like both but the Standard is more suited to my skill level.
Thanks To All
31 Mar 2013 02:15 #8318 by Archades
Replied by Archades on topic Standard Mixer Take-2
Quick question. In standard gui, can I change the output of channels for the cyclic? I helped setup a trex 500 and cyclic 1 and 2 were reversed, I managed to fix it with editing the model.ini but would prefer to just do it in the transmitter whilst keeping the standard gui. I can do it in advanced but prefer the standard interface for now.
31 Mar 2013 02:44 #8319 by Hexperience
Replied by Hexperience on topic Standard Mixer Take-2
Wouldn't you just adjust the cyclic mixing to a negative value? So rather than 60,60,60 you might have -60,-60,+60 ?
Maybe I'm not understanding the problem though...
Cheers
31 Mar 2013 03:00 #8320 by Archades
Problem was the pitch and ail servo's were getting each other's signal instead of their own.
31 Mar 2013 04:55 #8322 by sbstnp
Replied by sbstnp on topic Standard Mixer Take-2
Archades wrote: Problem was the pitch and ail servo's were getting each other's signal instead of their own.
Easier to swap connectors?
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
31 Mar 2013 06:44 #8328 by Archades
Easy but lazy, i wanted to do it the right way :P
Time to create page: 0.191 seconds
