Feature suggestion, Servo test mode
- Xermalk
20 Feb 2013 23:47 - 21 Feb 2013 00:28 #6653
by Xermalk
Feature suggestion, Servo test mode was created by Xermalk
So
I was wondering if its possible to implement a mode where the tx sends continuous channel input over a timeframe.
With configurable speed ,interval and intensity of the commands.
For example negative/positive pitch and right/left rudder for a helicopter.
This would let you do a bench test of your servos in a more realistic manner.
There would obviously have to be warnings before this mode activates, so that one does not have motors connected. Or having servos bind and burn out.
Edit: basically what im looking for is a pre-programmed macro of somesort that shakes all the servos at varying speeds and intensity for 5 minutes or so.
This would weed out the really bad servos before one takes of. And would also make for a decent test of servos after a crash.
Place a few helicopters next to eachother with this mode on and youd have a decent harlem shake video
Last edit: 21 Feb 2013 00:28 by Xermalk.
- chuneault
21 Feb 2013 01:22 #6656
by chuneault
Replied by chuneault on topic Feature suggestion, Servo test mode
Very good idea !!
- cmpang
21 Feb 2013 01:25 #6657
by cmpang
that was one of the few nice features in my aged Futaba FF9. With this, you can perform range check without other's help.
Set the FF9 in servo scan mode, let it stands and take your receiver to move around to see how far to go before servo gitter...
Replied by cmpang on topic Feature suggestion, Servo test mode
Xermalk wrote: So
- Hexperience
21 Feb 2013 02:11 #6660
by Hexperience
Replied by Hexperience on topic Feature suggestion, Servo test mode
Once PB moves the servo speed function so that it can be used in the mixer, then we can just program the mixer to do it.
I have a mix that does it now, but because the servo speed is not applied it just flips the channel back and forth about a million times a second... :0
- Xermalk
24 Feb 2013 16:49 #6965
by Xermalk
Well well well, that would be perfect for testing those 0.00001s servos
Replied by Xermalk on topic Feature suggestion, Servo test mode
Hexperience wrote: Once PB moves the servo speed function so that it can be used in the mixer, then we can just program the mixer to do it.
- Xermalk
20 Mar 2013 13:31 #7935
by Xermalk
Found a video of how this feature looks like on another transimtter.
- Xermalk
06 Jun 2013 17:40 #10646
by Xermalk
Was the servo speed function ever moved?
I would really like to have this feature for testing the servos on my 450 build.
07 Jun 2013 05:08 - 07 Jun 2013 05:11 #10663
Replied by PhracturedBlue on topic Feature suggestion, Servo test mode
Here's an example of an experimental 'delay' mixer I quickly coded up:
The mixer is a type (like replace, add, min, max) so it is only available as a 'Complex' mixer. It compares the Source to the calculated value (after applying scalar and curves) and then uses the offset as the 'speed' value. I need to think of a better way to do it, ideally without adding yet another variable to the mixer structure, but this shows that it is possible to code it into the mixer as we've discussed.
Last edit: 07 Jun 2013 05:11 by PhracturedBlue.
- Xermalk
07 Jun 2013 07:52 - 07 Jun 2013 07:56 #10673
by Xermalk
Nice, send me a pm and ill gladly test it out, if you have it ready in ~1 week.
Still waiting for a few parts so build is paused.
Last edit: 07 Jun 2013 07:56 by Xermalk.
07 Jun 2013 17:24 #10695
I have an implementation I'm happy with now.
When you set the mux-type to 'delay' the curve actually represents time for the servo to go from 0-100%.
So the typical use would be to have the 1st mixer define the expected value, and the 2nd mixer to apply a delay using a 'fixed' curve type (using 'scalar' to define the amount of delay). you could have non-linear delay as well if you are so inclined.
The question I have is how slow should it be?
typical servos can complete a 0-100% sweep in 0.1 to 0.2 seconds.
We have a total of 100 steps available.
Currently I am using 1 step = 0.1 second. So on a 0.1s servo, a value of '1' would have no effect, a value of '2' would be half speed, a value of '10' would take 1 second to go from 0-100%, and a value of '100' would take 10 seconds to go from 0-100%
There are other algorithms, but this one seems to make the most sense to me, so the question is really: What is the finest granularity you want control at? Is 1/10sec fine enough for 0-100% or should we go finer (at the cost of the slowest sweep)?
- Xermalk
07 Jun 2013 17:35 #10696
by Xermalk
Well, it is going to be used for stress testing the servos, and some of the top fbl servos are very very fast. Even clone servos can have speeds of 0.07s.
Could the granularity be written so we can have a modifier for it in the ini file or something? That would be the best from all viewpoints.
07 Jun 2013 18:51 #10697
I think that will be overkill. I've set it to 5sec 0-100. This looks like it will cover all uses (fyi, I believe the most common usage is actually for landing gear with a standard servo).
- Xermalk
07 Jun 2013 19:58 #10701
by Xermalk
Yeah, that's the most likely use.
Though any test you can do on the bench is one less risk of failure in the air.
Running the servos on the bench for 5-10 minutes and then checking so they aren't hot. Is a good way to minimize failures.
You could also do a poor mans brownout test by running the servos and motor at full speed. Obviously without any blades and strapped down to something robust.
08 Jun 2013 02:56 - 08 Jun 2013 02:56 #10704
I have checked in support for slow mixers now. Here is a example that shows a channel sweep using 1 virtual channel (3 mixers) and the output channel (2 mixers) There may be even better solutions, but this showcases the new capabilities.
FYI, I will likely remove support for the limits-based speed before the next release
Last edit: 08 Jun 2013 02:56 by PhracturedBlue.
- Hexperience
11 Jun 2013 17:41 - 11 Jun 2013 17:42 #10797
by Hexperience
I tried to load this in the devo12 emu, but it freezes at startup.
Using my emu build from the latest deviation.
Last edit: 11 Jun 2013 17:42 by Hexperience.
11 Jun 2013 17:51 #10799
Works fine for me in 0f23fad098e0
- Hexperience
11 Jun 2013 18:31 #10805
by Hexperience
My bad... I guess my clone of the repo was not clean... sorry.
- myxiplx
10 Jul 2013 05:38 #12161
by myxiplx
Replied by myxiplx on topic Feature suggestion, Servo test mode
Question, could this be used to program a soft start in the TX?
I may not need it, but I've just read a thread with tips about reducing startup wobble, and one piece of advice was to spool up at 0 pitch, using idle up and a soft start.
I have a nitro heli, so no ESC, but I'm wondering if I could program my own soft start. Would adding this delay setting to my idle up throttle mix work?
Time to create page: 0.512 seconds
- Feature suggestion, Servo test mode
