Super CP binding with brushless motor
21 Feb 2013 21:44 #6730 by quique65
Super CP binding with brushless motor was created by quique65
I've just installed a C05 brushless motor with a Walkera 10LT ESC on a Super CP. With a DEVO 7e, after a normal binding procedure with no fixed ID, few seconds after the led on the RX is fixed I can hear the tones of the ESC. When I give power (TH) the motor hasn't power to lift.
If during the binding procedure, just when the led on RX is fixed, I give a little power (TH) before hear the ESC tones, the motor starts properly. It seems that the ESC doesn't initialize correctly if I don't touch the throttle at the end of the binding process.
Has anyone experienced this?. Anyone knows why an a possible solution? Thank you.
22 Feb 2013 01:11 #6739 by Mullson
Replied by Mullson on topic Super CP binding with brushless motor
Drunkenness and control is everything ...
I dident crash or dident do what I felt like doing. If I crash the supermini titanno helimusel I have to fix it my self, cheers!
22 Feb 2013 01:14 #6740 by Mullson
Whats your gole with installing a brushless motor in a mini?
22 Feb 2013 01:22 - 22 Feb 2013 01:22 #6742 by cmpang
Replied by cmpang on topic Super CP binding with brushless motor
I have also installed a brushless motor in my miniCP for its long motor life and long flight time.
Get over 5 minutes flight time now that was only 3 minutes before the mod. Let alone the extra power.
Last edit: 22 Feb 2013 01:22 by cmpang.
22 Feb 2013 01:26 - 22 Feb 2013 01:31 #6745 by Mullson
Sorry for all the heat..
I am writing in the wrong thred.. sorry
Last edit: 22 Feb 2013 01:31 by Mullson.
  • rbe2012
  • rbe2012's Avatar
22 Feb 2013 13:55 #6811 by rbe2012
Replied by rbe2012 on topic Super CP binding with brushless motor
Mullson,
maybe a good time for going to sleep for a while. You're surely welcome but most of your statements do not really make sense at the moment...
Time to create page: 0.114 seconds
