SETUP PROBLEM WITH SUKHOI SU-35 AND DEVO 12S
22 Feb 2013 07:26 #6763 by christodoulou
SETUP PROBLEM WITH SUKHOI SU-35 AND DEVO 12S was created by christodoulou
DEAR FRIENDS IM TRYING TO SETUP MY DEVO 12S WITH THE EDF 70MM SUKHOI SU-35 FREEWING BUT I CANT DO IT AT ALL.THE ONLY I HAVE FOUND FROM INTERNET WAS JUST WITH A JR TRANSMITTER BUT ITS COMPLETELLY DIFFERENT.
I WOULD BE GLAD TO ANYONE TO HELP ME AND GUIDE ME HOW TO DO IT.
ALSO AFTER BINDING FIX ID MY DEVO 12S RESPOND ONLY TO THROTTLE SERVO AND WHEN I PLUG ALSO ALL THE OTHER SERVOS TO THE RX 1202 DOESNT WORK AT ALL,PLEASE HELP ME BECAUSE IM DESPERATE,NOBODY CAN HELP ME NOBODY ANSWER ME
RGDS
CHRISTOS
  • rbe2012
  • rbe2012's Avatar
22 Feb 2013 07:33 #6765 by rbe2012
Replied by rbe2012 on topic SETUP PROBLEM WITH SUKHOI SU-35 AND DEVO 12S
Do you talk about the Walkera stock firmware or deViation?
...and please don't use only CAPITALS
22 Feb 2013 09:49 #6781 by christodoulou
Replied by christodoulou on topic SETUP PROBLEM WITH SUKHOI SU-35 AND DEVO 12S
I'm talking about deviation transmitter
22 Feb 2013 12:15 - 22 Feb 2013 12:16 #6792 by RandMental
Replied by RandMental on topic SETUP PROBLEM WITH SUKHOI SU-35 AND DEVO 12S
I am still confused, lets clarify
Devo12s TX with Walkera standard firmware as you bought it?
OR....
Devo12s TX with the (latest) Deviation firmware, build for the Devo12s, loaded?
Last edit: 22 Feb 2013 12:16 by RandMental.
22 Feb 2013 12:27 #6793 by FDR
christodoulou wrote: I'm talking about deviation transmitter
The confusing part is that there is no "deviation transmitter".
We running "deviation firmware" on "devention transmitters"... ;)
22 Feb 2013 12:48 #6795 by christodoulou
Well my radio control is walkera devo 12s with devention devo RX1202 receiver.and i have uptaded the latest walkera devention firmware 1.4
Actualy as i bought it with standard walkera firmware and after i update it to 1.4
22 Feb 2013 12:52 #6796 by christodoulou
Devo 12s tx with walkera standard firmware and then updated with latest 1.4 deviation firmware
22 Feb 2013 12:54 #6798 by christodoulou
Yep your right so my friend any suggestions or help?
22 Feb 2013 13:33 #6808 by PhracturedBlue
Replied by PhracturedBlue on topic SETUP PROBLEM WITH SUKHOI SU-35 AND DEVO 12S
This forum is actually primarily for discussing a custom firmware that we've written from scratch for the Walkera radios. While there are a lot of knowledgeable people here, and someone might be able to help you (sorry, I don't really know enough to do so)m, you might get a faster response on one of the larger heli forums helifreak/rcgroups.
22 Feb 2013 15:08 - 22 Feb 2013 15:11 #6816 by RandMental
christodoulou wrote: Devo 12s tx with walkera standard firmware and then updated with latest 1.4 deviation firmware
We are still not able to help you as you are quoting equiment and software/firmware versions that do not exist. There is no Deviation V1.4 firmware version, only a Walkera Version V1.4 for the Devo12s.
The official Deviation firmware releases, which does not yet support the Devo12s, are listed here: www.deviationtx.com/release-notes .
Please go to www.deviationtx.com to see what this site and forum are about, and as PB suggested, you shall find more help on the Devo12S Walkera environment in RC Groups or on Helifreak.
Last edit: 22 Feb 2013 15:11 by RandMental.
Time to create page: 1.799 seconds
