Can't touch touchscreen my devo8s
07 Mar 2013 02:27 #7462 by leebu
Can't touch touchscreen my devo8s was created by leebu
First, Thanks very much for being able to use deviationtx.
Unfortunately, my devo8s shoud not work after deviation firmware upgrade.
It is touchscreen problem. Calibrate again again... it is useless, also firmware upgrade.
To explain my touchscreen ploblem, The entire area is able to touch on calibrate test.
Another parts, example model name, can't type most of the keyboard. possible that Q P A G I caps V del....
Can I solve this problem, what can we do about this?
07 Mar 2013 08:11 #7474 by Joshua
Replied by Joshua on topic Can't touch touchscreen my devo8s
What firmware version did you use?
07 Mar 2013 09:43 #7478 by leebu
Replied by leebu on topic Can't touch touchscreen my devo8s
Now, firmware 2.1.1 ; fs 2.1.0
sorry!
07 Mar 2013 09:47 #7479 by FDR
Replied by FDR on topic Can't touch touchscreen my devo8s
When you swtch models, does it save when turing off? i.e can it save to the tx.ini?
Also you can try to overwrite your tx.ini with the default one from the filesystem.zip...
07 Mar 2013 14:18 #7487 by FDR
Well, the calibration seems to be good.
However I'm not sure it supports dragging throw the keyboard...
How hard do you touch the screen?
To me it looks a bit too soft, so the contact is not reliable, it often senses more touches than needed...
07 Mar 2013 14:26 - 07 Mar 2013 14:35 #7490 by leebu
What's the problem?
In walkera version, It's quite normal.
Last edit: 07 Mar 2013 14:35 by leebu.
07 Mar 2013 14:34 - 07 Mar 2013 14:58 #7491 by leebu
Thank you very much for answer.
My devo8s is bad or new version!
Gonna use just by pressing a key, Surrender!!!
Last edit: 07 Mar 2013 14:58 by leebu.
25 Mar 2013 15:49 #8073 by leebu
Thank you very much!
Miracle's happened to me just before.
Which did not work until now I'm starting to touch.
I only got the battery case modifications.
I'm HAPPY!
Wonderful!
bonus pics
  • rbe2012
  • rbe2012's Avatar
25 Mar 2013 20:11 #8077 by rbe2012
Replied by rbe2012 on topic Can't touch touchscreen my devo8s
Hmm, looks strange. Can it be a contacting problem? The lcd (with touch surface) has its own board and a multi pin header to the main board...
I don't believe that the voltage was too low before because many of us run with NiMH / NiCD and similar without problems. Maybe a bad regulator?
Time to create page: 0.285 seconds
