Devo 7e switch mix up
- 944storm
13 Mar 2013 21:54 #7713
by 944storm
Devo 7e switch mix up was created by 944storm
I recently acquired a 7e and installed the latest nightly on it. Everything seemed to work well until I hit the hold switch, it did nothing. Yes I did set it up so that it would move throttle to -100. Funny thing is the fmode switch and throttle hold are reversed when I watch them in the transmitter setup screen. Any one else have this issue?
- dc59
14 Mar 2013 00:31 #7721
by dc59
Did you check "Switch Assignment" page setting?
Replied by dc59 on topic Devo 7e switch mix up
944storm wrote: I recently acquired a 7e and installed the latest nightly on it. Everything seemed to work well until I hit the hold switch, it did nothing. Yes I did set it up so that it would move throttle to -100. Funny thing is the fmode switch and throttle hold are reversed when I watch them in the transmitter setup screen. Any one else have this issue?
- 944storm
14 Mar 2013 00:48 #7725
by 944storm
Replied by 944storm on topic Devo 7e switch mix up
Yes I did. I'm thinking the switches were physically reversed by the previous owner. I'm going to take it apart and see if that is what happened. I went through everything. The stick input page shows t-hold activating fmod and vice versa.
- Xermalk
14 Mar 2013 11:52 #7741
by Xermalk
Replied by Xermalk on topic Devo 7e switch mix up
The switches are correct in the firmware, so the previous owner has to have swapped them.
Should only be a case of swapping over the connectors again though.
- 944storm
14 Mar 2013 22:51 #7763
by 944storm
I checked this morning and they were swapped. Switched them back and figured since I have it open I shorted diode (the one jnder the shield for more power) and added two switches. Need to do the patch update tonight.
Time to create page: 0.387 seconds
- Devo 7e switch mix up
