Transmitter Keeps Resetting
- Yaw2
16 Mar 2013 14:47 #7810
by Yaw2
Transmitter Keeps Resetting was created by Yaw2
Hello All,
I am a beginner to this hobby and I recently bought a Blade 130x. I am using the devo 8 transmitter and I am trying to program the settings that another user has already posted to this forum. When I am programming channel 1, I need to have 3 mixers so I made it three, but when I try to program mixer two or three my transmitter resets itself when I click to change the switch to fmode1. To be more clear on mixer 2 in channel 1, I try to change the switch from none to fmode1 and the transmitter resets itself. Does anyone know how to fix this problem?
16 Mar 2013 15:11 #7811
Replied by vlad_vy on topic Transmitter Keeps Resetting
It fixed at releases after v2.1.1. Next stable release will be soon. Right now you can try experimental Nightly builds.
www.deviationtx.com/repository/Deviation...ases/Nightly-Builds/
- Yaw2
16 Mar 2013 15:33 #7814
by Yaw2
Replied by Yaw2 on topic Transmitter Keeps Resetting
wait the problem has been fixed? I have to get a newer release?
16 Mar 2013 16:01 #7818
You can use last Nightly build, it's quite stable.
- Yaw2
16 Mar 2013 16:23 #7823
by Yaw2
I put the nightly build fs on, but what is the emu file, and how do I use it?
16 Mar 2013 16:45 #7828
It is Tx emulator for Windows.
- Tom Z
16 Mar 2013 16:49 #7830
by Tom Z
Replied by Tom Z on topic Transmitter Keeps Resetting
Yes. I am using it on Windows 7 Pro 32 bit. I use it to make models to post on this site.
Time to create page: 0.168 seconds
- Transmitter Keeps Resetting
