Couple questions for 3.0
08 Apr 2013 20:38 #8759 by jvulte
Couple questions for 3.0 was created by jvulte
First off,.. LOVE IT!!! Especially the low batt warning, lol.
There are a couple of things I am wondering about. For the countdown timers, my only options for switch, are None, or Ch3. I have my Gear switch unassigned, and would like to bind the gear switch to the timer. Is there a way I can make it my timer switch again?
This one is a bigger deal to me. I wish I could change how, when I turn on throttle hold, (RUD DR) my ch6(pitch) changes from its pitch curve to straight up -100 to 100. This in turn makes the servos snap pitch to -100% when I use throttle hold. Is there a way to change this?
Attached is my setup, if that helps
09 Apr 2013 04:07 - 09 Apr 2013 04:08 #8771 by vlad_vy
Replied by vlad_vy on topic Couple questions for 3.0
For timer, I think it's possible with Advanced Mixer only.
For pitch curve, I think you need deactivate Throttle Hold for Pitch curve. Or change pitch curve for Throttle Hold state to any curve you need.
Last edit: 09 Apr 2013 04:08 by vlad_vy.
  • rbe2012
  • rbe2012's Avatar
09 Apr 2013 05:54 #8774 by rbe2012
Replied by rbe2012 on topic Couple questions for 3.0
Vlad is right in both cases.
While playing around I noticed that the values displayed are not the expected. I have loaded a new model, changed to standard and loaded the 6Ch-template.
I tried to play with the issues jvulte mentioned and suddenly came to this:
This is obviously wrong. When you change the "H" value the graph changes as expected, but when you change the "M" value it also changes the H-point...
When I first looked at the curves everything was fine. I don't know when it changed.
I will file a ticket on bitbucket for this.
09 Apr 2013 14:12 #8782 by PhracturedBlue
Replied by PhracturedBlue on topic Couple questions for 3.0
I am unable to reproduce this behavior on the emulator after following what you've got above. It probably means some variables are getting corrupted, so if you can document step-by-step from a clean model exactly what you pressed so I can see it, it would definitely help
09 Apr 2013 14:55 - 09 Apr 2013 15:25 #8784 by vlad_vy
I get the same result as above (Devo8).
1) loaded a new model,
2) changed to Standard GUI,
3) loaded the 6Ch-template.
I'm not shure it is correct to load Heli 6Ch-template with Standard GUI.
at template: curvetype=5point
at Standard GUI: 9point
Last edit: 09 Apr 2013 15:25 by vlad_vy.
09 Apr 2013 14:59 #8786 by FDR
Replied by FDR on topic Couple questions for 3.0
vlad_vy wrote: I get the same result as above (Devo8).
I don't think so...
  • rbe2012
  • rbe2012's Avatar
09 Apr 2013 14:59 - 09 Apr 2013 15:00 #8787 by rbe2012
It is very easy. I cloned your actual repo (parent: 1582:1ae61a3d88c3 tip (Fix default icon assignments. Fixes #319) in a new directory so all files were created new, ran "make TARGET=emu_devo8 WINDOWS=1" and started the emu.
Then I took a new model, switched to standard mixer gui, loaded the 6-ch-template (:blush:) and looked at the throttle curve.
I have made a screen video where you can see this:
File Attachment:
File Name: video.zip
File Size:200 KB
When you look at the video you will throw your hands up in horror... I have realized yet what I have done and I know now that it was wrong.
My fault, maybe, but this is a way which is not suppressed from the gui - so I will not stay the last who tries it. Choosing a template when the standard gui is selected should only allow the "Heli/Standard GUI" template (or the mode should be reset to advanced).
EDIT: This will be my destiny: every time someone is faster than me...
Last edit: 09 Apr 2013 15:00 by rbe2012.
21 May 2013 20:40 #10213 by jvulte
Replied by jvulte on topic Couple questions for 3.0
Back at what I was wondering before, I have become more familiar with the system now. When using STANDARD mode, enter the PITCH CURVE menu. NORMAL,IDLE UP 1, IDLE UP 2, THROTTLE HOLD so here I can change the pitch curve to whatever I want when throttle hold is on. Be it, straight 0 across the board to try and save servos, or -60 to +60 to practice Auto rotations. Thanks again for my DEVIATION!!!! :D
Time to create page: 0.809 seconds
