Devo 10 problem
- pete-c
10 May 2013 15:04 #9802
by pete-c
Devo 10 problem was created by pete-c
Hi
When I switch my Devo10 on I get the FLIGHT SWITCH sign in a rectangle box similar to that if you have the throttle open but i can't get rid of it. Can anyone help me with this problem?
Regards
Pete
Regards
Pete
10 May 2013 15:10 - 10 May 2013 15:10 #9803
Replied by FDR on topic Devo 10 problem
In which position your flight mode switch is?
It sould be in FMOD 0, otherwise it is in idle up mode...
Last edit: 10 May 2013 15:10 by FDR.
- pete-c
10 May 2013 15:21 #9804
by pete-c
Replied by pete-c on topic Devo 10 problem
Have tried it in all positions it does not make any difference. Could it be a faulty FMOD switch?
Pete
Pete
- sbstnp
10 May 2013 15:36 #9805
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Replied by sbstnp on topic Devo 10 problem
Most probably yes. Looks like you're running stock firmware though.
If you go ahead and flash Deviation you can ignore FMODE switch on your models until you fix it.
Devo 10 + 4in1
- pete-c
10 May 2013 15:41 #9806
by pete-c
Thanks for that but how do I flash deviation?
Pete
sbstnp wrote: Most probably yes. Looks like you're running stock firmware though.
Pete
- pete-c
10 May 2013 15:46 #9807
by pete-c
Hi
Have found how to do it. Will give it a try.
Regards
Pete
Regards
Pete
Time to create page: 0.213 seconds
- Devo 10 problem
