replacement stock 2.4 module
- airheli1201
13 May 2013 20:39 #9944
by airheli1201
replacement stock 2.4 module was created by airheli1201
Hi all.
I was wondering if anyone knows if there is a replacement for the stock 2.4 module.
The reason I am asking is because as I was doing the increase range mod, I messed up in the process. I basically burnt one of the the connection point of the diode so solder no longer flows ( I think I was able to connect two point but am not certain, as it's hard to see) on it as well as destroyed the resister beside due to my soldering iron being too close.
However, I am still able to control bind and control my model. I am relived of that but don't want to rick losing control of the model in the air trying it out.
Anyone advise me?
Many thanks in advance!
Anyone advise me?
- airheli1201
13 May 2013 20:45 #9945
by airheli1201
Replied by airheli1201 on topic replacement stock 2.4 module
I wonder if
www.rc711.com/shop/walkera-devention-upg...72.html?cPath=167_24
works?
- domcars0
13 May 2013 20:58 #9946
by domcars0
Replied by domcars0 on topic replacement stock 2.4 module
Yes it works!
- airheli1201
13 May 2013 21:16 #9947
by airheli1201
Thanks for the info but do you by any chance have details on how to do it? I did a search on google but cant find any information about it.domcars0 wrote: Yes it works!
- domcars0
13 May 2013 21:43 #9949
by domcars0
- airheli1201
13 May 2013 21:50 #9950
by airheli1201
My bad. I
I forgot to mention that it's a 7e. haha
13 May 2013 22:02 #9953
Replied by PhracturedBlue on topic replacement stock 2.4 module
I think he wants to install it into a devo7e.
Yes it will work. There was a discussion on these forums about doing it a couple months ago, it is not too hard to do.
13 May 2013 22:08 #9954
Also, you'll need to get an antenna wire since the module doesn't come with one.
Something like this will work well with the stock antenna tube:
www.ebay.com/itm/FrSky-2-4-Ghz-400mm-Rx-...&hash=item416b36495b
- airheli1201
13 May 2013 22:34 - 13 May 2013 22:34 #9957
by airheli1201
Thank you for your help.
like you said it did appear in past post. I had to search for WK-21201RF instead of WK-DEVO-S-MOD
For those who are wondering the same thing. The following is
the 8s module pinout (using the numbering in the flysky docs):
1: chip select
2: SCK
3: GND
4: MOSI
5: MISO
6: V+
10:Reset
The Devo7e:
1) Chip Select
2) SCK
3) MISO
4) MOSI
5) Reset
6) V+
7) GND
So happy I can still use this tx. Really love the design and Deviationtx!
PhracturedBlue wrote: I think he wants to install it into a devo7e.
1: chip select
2: SCK
3: GND
4: MOSI
5: MISO
6: V+
10:Reset
The Devo7e:
1) Chip Select
2) SCK
3) MISO
4) MOSI
5) Reset
6) V+
7) GND
Last edit: 13 May 2013 22:34 by airheli1201.
- airheli1201
13 May 2013 22:45 - 13 May 2013 22:46 #9958
by airheli1201
Now the question is which direction does the pinout on the devo 8s go?
www.rc711.com/shop/imagemagic.php?img=nN...800&h=600&page=popup
Last edit: 13 May 2013 22:46 by airheli1201.
13 May 2013 23:18 #9961
look at the docs for installing a module on your radio in the 'Downloads' section. You'll find a pic that labels the pins
- Fishfiend
15 May 2013 19:13 #10036
by Fishfiend
Replied by Fishfiend on topic replacement stock 2.4 module
This would be great, unfortunately I cant find stock anywhere...
The only place that has them is wow hobbies at 3 x the price of the China sellers, and from the US it takes ages to the UK....
15 May 2013 19:22 #10038
Replied by FDR on topic replacement stock 2.4 module
You are right, everywhere seems to be out of stock, except this one:
www.hobbyone.com.hk/cn/product.jsp?id=10896
- sbstnp
15 May 2013 19:26 - 15 May 2013 19:27 #10039
by sbstnp
They're not as nice as Miracle Mart to work with, but they have stock. They're actually owned by Walkera.
Edit: Pfff FDR beat me to it.
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Replied by sbstnp on topic replacement stock 2.4 module
Fishfiend wrote: This would be great, unfortunately I cant find stock anywhere...
Devo 10 + 4in1
Last edit: 15 May 2013 19:27 by sbstnp.
16 May 2013 02:39 - 16 May 2013 02:40 #10046
Someone had mentioned that Walkera stopped selling these modules and all that is left is unsold stock, as the original purpose was to upgrade Devo8/12 and now that the module has been out for a year or so, they figured everyone who is going to has already done so. That may explain the stock. I don't kow if the above is true or just a rumor.
Last edit: 16 May 2013 02:40 by PhracturedBlue.
- Fishfiend
16 May 2013 12:44 #10054
by Fishfiend
Just come back into stock at
www.ehirobo.com
pretty quick from HK to UK..unfortunately price is now $20.
- blackmoon
16 May 2013 20:29 #10058
by blackmoon
Replied by blackmoon on topic replacement stock 2.4 module
S**t! I knew I should have bought it when it was 10$
- spiegel
20 May 2013 15:27 #10157
by spiegel
Replied by spiegel on topic replacement stock 2.4 module
In order to replace 7e module with 8s's I am going to remove the original one.
But there are unknown soldering spots as below picture in blue circle.
Do these spots have specific purposes or just glue the module?
Please let me know otherwise let me know the whole process of the removing the module.
- domcars0
20 May 2013 17:15 #10159
by domcars0
I think this spots are just for well 'ground' (put a good 0 Volt) the module.
- RandMental
20 May 2013 18:59 #10162
by RandMental
and mechanical strength to take strain of the soldered connections when the Tx is bumped or dropped.
Replied by RandMental on topic replacement stock 2.4 module
domcars0 wrote: I think this spots are just for well 'ground' (put a good 0 Volt) the module.
Time to create page: 1.490 seconds
- replacement stock 2.4 module
