devo12 with rx1202 range problem?
20 May 2013 10:58 #10140 by Hexperience
devo12 with rx1202 range problem? was created by Hexperience
Flew a plane yesterday with my devo12 and the rx1202 that came with it. Also had the telemerty module unstalled. Got to about 300 feet and lost all control. Lucky I had a plastic bag with me to pick up the remains... :(
Tx was set to 100mw. Anyone have range issues with this combo? I have been flying the devo12 a lot but all helis and an edge540qq so I never got very far away. It's been perfect up until now.
So how can I do a reliable range test before I try the rx1202 again?
20 May 2013 12:24 #10144 by Hexperience
Replied by Hexperience on topic devo12 with rx1202 range problem?
Update... range checked an rx601 at 100umw and got about 15 feet. Range checked the rx1202 at 100umw and only get about 1 foot... bad rx... should have done that before... :(
Anyone know the math? If I get 10 feet at 100umw what should I get at 100mw?
Thanks...
20 May 2013 13:24 #10151 by FDR
Replied by FDR on topic devo12 with rx1202 range problem?
Open up the rx and check the antenna wire, especially at the soldering point.
20 May 2013 14:08 #10153 by vlad_vy
Replied by vlad_vy on topic devo12 with rx1202 range problem?
Hexperience wrote: Anyone know the math? If I get 10 feet at 100umw what should I get at 100mw?
Square root from power change. 100uW -> 100mW = 1000 or 30 times of range
20 May 2013 19:41 #10168 by Hexperience
Thanks guys used the 601 for a few flights this morning. No range problems at all.
20 May 2013 23:15 #10178 by Hexperience
Opened it up and the antenna are connected with those micro connectors . (not sure what they are called).
Can't really tell if there is any bad solder points, the soldering is super small.
I'll just send it back to where I got it and see if they replace it.
21 May 2013 08:37 #10186 by Pattaya01
Replied by Pattaya01 on topic devo12 with rx1202 range problem?
I noticed when I have my TX antenna not pointing up, I also had a range problem. When it was in parallel to the ground, there were many glitches. As soon as I had it straight up, range OK.
21 May 2013 10:37 #10190 by Hexperience
I have the tx and rx antennas parallel to each other so that should be the best possible signal. I'll give it a try just to see but my plane doesn't stay parallel to the ground very much. ;)
Of course the place I bought it is telling me to read the instructions first before sending it back...
Time to create page: 0.121 seconds
