Can`t switch to standard GUI
- gagamel
07 Jul 2013 15:03 #12043
by gagamel
Can`t switch to standard GUI was created by gagamel
Hello
I have now the deviation 3.0 with a DEVO 10. But I can`t switch to standard GUI.
I`m always in the advanced mode. Is this normal?
Greetings and thanks for help
- gagamel
07 Jul 2013 15:28 #12045
by gagamel
Replied by gagamel on topic Can`t switch to standard GUI
Ok, solved the problem. Made a new install and didn`t changed the language.
In english all works fine
07 Jul 2013 17:37 #12046
Replied by rbe2012 on topic Can`t switch to standard GUI
This shouldn't be a question of the selected language. Can you explain what exactly did not work? Has the select box been disabled or invisible? Has been no other value to select but advanced? Which language did you use when it did not work?
- gagamel
08 Jul 2013 08:06 #12068
by gagamel
I selected german language. Then Mixer Gui was on advanced. If I wanted to change to standard, there was a message, that my model setup will be lost. I clicked ok and then I was still in the advanced mode.I tried it for 8 or 9 times, but I always was in the advanced mode.
08 Jul 2013 08:16 - 08 Jul 2013 08:42 #12069
Ok, i will look at this.
EDIT: I destroyed my build environment accidentally so I will look in the evening...
Last edit: 08 Jul 2013 08:42 by rbe2012.
08 Jul 2013 09:40 #12072
(Just a minor issue, my build env runs again)
Besides some missing / crude translations I can't find any issues when switching from advanced to standard mode and back - neither in English nor in German.
Are you using the official 3.0.0-version or one of the nightlies (the actual code works too)?
Did you make some special configurations before switching?
- gagamel
08 Jul 2013 16:20 #12093
by gagamel
As I said I made a second try to install the deviation Software and now no problems. Maybe I made a mistake with my first install.
09 Jul 2013 05:28 #12118
Ah, I have understood that you have no problems only when you stay in English.
Enjoy!
Enjoy!
Time to create page: 0.068 seconds
- Can`t switch to standard GUI
