servo 90 trim on v120 with rx 2636h ?
- Zomaar
09 Jul 2013 12:08 - 09 Jul 2013 12:10 #12134
by Zomaar
servo 90 trim on v120 with rx 2636h ? was created by Zomaar
I've got a v120do2v2 but out of the box the servos were way off.
so I started to get them to 90 but mechanical it is still off
its rather bad on 2 servo's.
But I fail to find the servo sub trim on the Devo 8 (3.0.0 standard no nightly)
The subtrim in the channel move the multiple servo's together instead of moving 1 servo. (or is this a conceqence of the 1 servo swash type ? )
Also I'm wondering on doing the adjust mode on the 2636h , do I just switch the wk <> dipswitch to adj and then subtrim ? Or do you need to startup with the switch already in adjust mode, just switching does make any difference ?
Grtz,
Grtz,
Last edit: 09 Jul 2013 12:10 by Zomaar.
- Hexperience
09 Jul 2013 12:28 - 09 Jul 2013 12:29 #12135
by Hexperience
Replied by Hexperience on topic servo 90 trim on v120 with rx 2636h ?
You found the subtrim, but on that heli it will do exactly what you are seeing.
Yes, you need to have it in adj mode, I don't think you have to power up to get adj, you just need to flip the switch. But it couldn't hurt..
Here's a vid I found that explains it.
Last edit: 09 Jul 2013 12:29 by Hexperience.
- Zomaar
09 Jul 2013 19:54 #12146
by Zomaar
Replied by Zomaar on topic servo 90 trim on v120 with rx 2636h ?
well, in the end I had I was doing everything like in the vid.
But I was just put off by the fact that indiviual servo trim was not supported.
Time to create page: 0.069 seconds
- servo 90 trim on v120 with rx 2636h ?
