Switch beeper
11 Jul 2013 05:52 #12173 by magic_marty
Switch beeper was created by magic_marty
Would it be possible to add a beeper to a switch? Say i want to have it beep when i have a assigned switch flipped..to remind me i have a certain mode selected.If i am flying my T copter in ACRO mode there is no beep but when i flip the switch to self level the TX beeps every second or so to remind me i am in self level mode...Would be cool to have different styles of beeps like a short beep for one mode and maybe a double beep beep then a pause and beep beep again for a different mode? Just a thought..
Thanks all... :)
11 Jul 2013 15:40 #12187 by clearprop88
Replied by clearprop88 on topic Switch beeper
I have a related request.
My Spectrum DX8 warns me with an alarm when any switch is on, and also if the throttle is up when I turn on the TX.
I think this is an important safety feature.
Is it possible to include this feature in the next Deviation release?
11 Jul 2013 16:51 #12189 by FDR
Replied by FDR on topic Switch beeper
There is a safety warning in deviation at startup, but you can only configure it in the ini file.
By default there is a safety section like this:
[safety]
auto=min
...which means the throttle channel apropriate to the current protocol should be at it's minimum value at startup, otherwise a warning message is shown.
However you can specify additional values for other channels too...
