Axe 100CP doesn't get full throttle
- Nez
20 Jul 2013 16:14 #12375
by Nez
Axe 100CP doesn't get full throttle was created by Nez
I've attached the .ini file for my Axe 100CP. I am having problems with the throttle on a Devo 8s with anylink. I also have the rtf controller Tactic TX610. The throttle seems to go much faster with it. I'm pretty new to all of this. Thanks in advance.
- rototophe
20 Jul 2013 16:35 - 20 Jul 2013 16:37 #12376
by rototophe
Replied by rototophe on topic Axe 100CP doesn't get full throttle
Just for fun I suggest you try binding the Axe 100CP using the "J6PRO" protocol, don't use anylink or anything, just select the J6PRO protocol from the protocol drop down list and try to bind.
The Axe100CP is a rebranded Nine Eagle SoloPro 125.... My guess is it should bind to the Nine Eagle "J" protocol.
See if it works, if it does all your problems are solved
Last edit: 20 Jul 2013 16:37 by rototophe.
- Nez
20 Jul 2013 19:09 #12385
by Nez
Replied by Nez on topic Axe 100CP doesn't get full throttle
I'll try it for fun but i looked into before i bought devo and it sounded like the boards are different. I dont think it will solve my problem anyway as i think the problem is in how i have it set up in tx. ill post later to let you know if j6 works.
- rototophe
21 Jul 2013 19:59 #12408
by rototophe
Any luck binding the AXE 100 CP to Deviation using J6Pro protocol?
Note: you need a Devo Tx with a telemetry capable module to use the J6Pro protocol (not that the protocol actually uses telemetry) so you need a "S" Devo.
- Nez
23 Jul 2013 03:20 #12440
by Nez
doesnt work. its slt protocol.
- rototophe
23 Jul 2013 19:27 #12457
by rototophe
Disapointing ...
Thanks for verifying this for me.
- Hexperience
26 Jul 2013 22:52 #12538
by Hexperience
Replied by Hexperience on topic Axe 100CP doesn't get full throttle
It's not disappointing in regards to deviation. It was the old Solopro 125 that used J6Pro protocol. Even the solopro is now using something close to the anylink.
Nez, did you ever get it worked out?
Looking at your ini file I see a lot of "curvetype=deadband". I don't normally look at the raw ini files, so maybe that is the default for an unused curve(?)
I'm finding that I have way too much control. I have to set my rates to 50%.
I really think this all has to do with the calibration of the PPM signal compared to spektrum PPM. I'm going to plug in my dx6i and my devo12 to Phoenix and see what the rates look like.
- Nez
02 Aug 2013 16:14 #12727
by Nez
I think I may have some bad batteries confusing the situation. I'm not sure. It seems like my heli-max 1SQ is slower with Devo8s and anylink as well though. I also have a flyzone S.E.5a and it seems to get full throttle I think. I'm going to do some trial and error this weekend and try to compare the same flight battery on tx610 then devo 8s to determine what's going on. Is there any way to adjust the trottle above 100 percent in devention? My tx610 has 125 percent for ail/elev/rud but not throttle.
- Nez
02 Aug 2013 17:47 #12729
by Nez
I just realized its at full positive pitch now no matter I do. I tried reversing channel 6 etc. I think the problem may be that this anylink thing is junk.
- sbstnp
03 Aug 2013 02:32 #12735
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Replied by sbstnp on topic Axe 100CP doesn't get full throttle
You can go way higher than 125 with Deviation.
Make sure you're sending the correct channel to the Anylink thing.
Devo 10 + 4in1
- Nez
03 Aug 2013 16:41 #12745
by Nez
i got pitch worked out. it seems i accidentally changed it to plane instead of heli at some point. still flies better with tx 610. not sure what you mean by way higher than 125 though. it seems like its limited to 100 in advanced mode.
- Nez
03 Aug 2013 20:54 #12747
by Nez
Hex, have you set up gyro gain on channel 5? Maybe thats why you have so much control. I have it set up on the mix switch. My rates are on fmode at 60/80/100.
I use it on 100 most of the time and it seems to control nice.
05 Aug 2013 05:02 #12765
Replied by FDR on topic Axe 100CP doesn't get full throttle
On the channel's settings you can use the scale values to scale it over 100%Nez wrote: ...not sure what you mean by way higher than 125 though. it seems like its limited to 100 in advanced mode.
Time to create page: 0.108 seconds
- Axe 100CP doesn't get full throttle
