DEVO7E Can't get off main page config
31 Jul 2013 19:46 #12661 by blackmoon
DEVO7E Can't get off main page config was created by blackmoon
I'm using deviation-devo7e-v3.0.0-ddf6350.zip nightly.
If I do a Model Menu -> Main page config -> Load (loading a template) then I do an EXT or load a template.
I can't go back to the upper menu and have to reboot the TX.
I don't see this reported as a bug.
Is this already resolved in subsequent releases ?
  • rbe2012
  • rbe2012's Avatar
01 Aug 2013 06:32 #12681 by rbe2012
Replied by rbe2012 on topic DEVO7E Can't get off main page config
You have the latest nightly installed so there is no newer version where this issue is solved.
I have no Devo7e for testing so I can't help further. Filing a ticket is a good idea.
Can anybody confirm this as a bug?
01 Aug 2013 06:38 - 01 Aug 2013 06:49 #12682 by vlad_vy
Replied by vlad_vy on topic DEVO7E Can't get off main page config
You can check this with emulator. After template loading is impossible to exit from Main page config. Also you can't see layout by long press ENT, even message 'Layout: Long-Press ENT' is absent.
P.S. The same for Devo 10 emulator. After loading template you can long press ENT and see layout, but can't exit from Main page config.
Last edit: 01 Aug 2013 06:49 by vlad_vy.
  • rbe2012
  • rbe2012's Avatar
01 Aug 2013 07:08 #12683 by rbe2012
Ok, I will take a look in the code.
01 Aug 2013 07:20 #12684 by blackmoon
Replied by blackmoon on topic DEVO7E Can't get off main page config
Thank you for looking into this.
Should I file a ticket anyway on bitbucket ?
  • rbe2012
  • rbe2012's Avatar
01 Aug 2013 14:09 #12694 by rbe2012
Yes, please.
  • rbe2012
  • rbe2012's Avatar
01 Aug 2013 14:25 #12696 by rbe2012
Or better: don't do it.
After a look in the code I have seen that the relevant lines are only compiled in the code conditionally. It is inside the code for the 128x64-resolution main_config-page where some lines are only included for the devo10.
I am quite sure that this is a result of the little free space in devo7e. I seem to remember that somewhere this was discussed already and PB declared that he had to reduce some functions of the software to save memory.
  • rbe2012
  • rbe2012's Avatar
01 Aug 2013 15:03 #12697 by rbe2012
Funny...
I compiled with the switch set and the linker tells me that the image is too large...
But this is not the point - not getting back is indeed an error and not caused by the switch.
I will look again.
Time to create page: 0.133 seconds
