- What's the easiest way for me to get PPM, 5v?
- ummagawd
09 Aug 2013 00:53 #12849
by ummagawd
What's the easiest way for me to get PPM, 5v? was created by ummagawd
On my devo 10... i'd like to run openLRS which is looking for PPM, 5v, and GND.
Does the trainer port provide all these? or just the PPM signal?
09 Aug 2013 02:21 #12851
Replied by PhracturedBlue on topic What's the easiest way for me to get PPM, 5v?
You can get ppm, but only 3.3v. you can try to see if it is enough (3.3v may actually trigger as a logical 1 in many implementations)
- ummagawd
09 Aug 2013 02:37 - 09 Aug 2013 02:37 #12852
by ummagawd
Replied by ummagawd on topic What's the easiest way for me to get PPM, 5v?
thanks Phractured.
Are you implying that I can get 3.3v out of that trainer port? What about gnd?
Also, would the best way to find out which signal is which, via a multi-meter (and just hunt the 3.3v, -3.3v would be gnd, and then anything other than 3.3v is PPM?
Will I be able to get this from cutting up the supplied DCS cable?
Last edit: 09 Aug 2013 02:37 by ummagawd.
09 Aug 2013 04:56 #12856
Replied by FDR on topic What's the easiest way for me to get PPM, 5v?
There is no supply voltage on the trainer port, he only talked about the PPM signal level...
Time to create page: 0.097 seconds
