Devo 7E original software
- SilbernerSurfer
16 Sep 2013 05:55 #13812
by SilbernerSurfer
Devo 7E original software was created by SilbernerSurfer
how can i go back to the original software?
I found the files at walkera.com! but how have i to install the files. there are tow files . one can i install. the other is a lib file. what have i to do with it?
16 Sep 2013 07:40 #13814
Replied by rbe2012 on topic Devo 7E original software
Although I think it is not correct to help you going back... you are definitely on the wrong track...
Ok: in dfuse-tool there are three tabs (firmware, config, library). Choose library and install the second file there.
16 Sep 2013 07:48 #13816
I would add that you have to UPGRADE the library file not upload. Very important, because otherwise you spoil the library file...
Replied by FDR on topic Devo 7E original software
- domcars0
16 Sep 2013 19:13 #13833
by domcars0
Replied by domcars0 on topic Devo 7E original software
+1rbe2012 wrote: Although I think it is not correct to help you going back... you are definitely on the wrong track...
Time to create page: 0.314 seconds
- Devo 7E original software
