Devo f7 for DelFly
11 Mar 2014 05:11 #21445
Replied by PhracturedBlue on topic Devo f7 for DelFly
I'm not sure of any progress, but you can back up your models with the DfuSe tool before upgrading the memory. The updated memory should work fine with the original firmware as well until Deviation is ready.
- djtrance
12 Mar 2014 03:18 #21492
by djtrance
Replied by djtrance on topic Devo f7 for DelFly
thanks PB for your answer.
- djtrance
26 Mar 2014 21:29 #21876
by djtrance
PB,
the original firmware can't write on the 32mb memory, I don't know why. and when i put the priginal memory back to devo, the de vo can write, but when is trying to read, the mempry returning 0x00.
Do you think that the memory are die? (maybe when i put the memory again)
- Nickey
08 May 2014 04:15 #22987
by Nickey
Replied by Nickey on topic Devo f7 for DelFly
Do you have any progress?
- djtrance
08 May 2014 16:30 #23020
by djtrance
deviation is working in this tx, but there are a lot of things that must be fix it before to lunch the oficial release. for know I can only test it on the emulator, because when I change the memory (you must solder a new memory because the original has not space for deviation) my devo can't write on it and when I put the original memory again, for some reason can write on the memory but cannot read it. I will try to re solder the memory again, but I will try tu put some socket, for change the memory without solder the pcb tomuch times.
but if you want, and can, you can download the emultor and the code, and can help us to resolve the problems more faster, because now, the only person that are wornkin on this port is Microuav with some of help from PB
Time to create page: 0.110 seconds
- Devo f7 for DelFly
