Newbee wanting to go back to devention
14 Oct 2013 04:55 #14591 by Scootermcgavin
Newbee wanting to go back to devention was created by Scootermcgavin
I am running a devo 6 and am wondering how to go back to the original firmware.
14 Oct 2013 05:03 #14592 by FDR
Replied by FDR on topic Newbee wanting to go back to devention
The same way you used to upgrade it: download the fw and library from Walkera, and upgrade (NOT UPLOAD) the fw and lib using DfuSe...
14 Oct 2013 05:10 #14593 by Scootermcgavin
Replied by Scootermcgavin on topic Newbee wanting to go back to devention
are you talking about downloading the Dfuse usb upgrade tool?
14 Oct 2013 05:18 #14594 by Scootermcgavin
When Im in the Dfuse tool it wont let me click to upgrade
14 Oct 2013 05:57 #14595 by vlad_vy
Replied by vlad_vy on topic Newbee wanting to go back to devention
1. Press 'EXT' button and power on Devo 6
2. Run Dfuse
3. At 'Firmware' tab select at 'Upgrade File' = firmware file
4. Press 'Upgrade'
5. At 'Library' tab select at 'Upgrade or Verify File' = library file
6. Press 'Upgrade'
16 Oct 2013 03:53 #14680 by Scootermcgavin
Hi vlad_vy, I'm following the instructions and I see were youre telling me to click on Upgrade however it is not allowing me to select it as an option.
16 Oct 2013 04:09 #14681 by FDR
Does your DfuSe recognize the tx?
It should be displayed in the top left dropdown...
16 Oct 2013 04:28 #14682 by Scootermcgavin
It says "STM Device in DFU Mode" in the drop down
16 Oct 2013 04:32 #14683 by Scootermcgavin
I think it is recognizing as it says Devention DEVO-6 Transmitter at the very bottom when I turn it on.
16 Oct 2013 05:06 - 16 Oct 2013 05:08 #14684 by vlad_vy
You need select Devo 6 firmware file at (15) and press (6) button to upgrade
You need select Devo 6 library file at (22) and press Upgrade button to upgrade
Last edit: 16 Oct 2013 05:08 by vlad_vy.
16 Oct 2013 21:44 #14708 by Scootermcgavin
How do I find the devo 6 firmware in 15? When I click on 15 it open my document library. Where do I go from there? When I search using "devo" it finds nothing.
Thanks so much for your help thus far guys
17 Oct 2013 21:38 #14739 by Scootermcgavin
Thanks vlad_vy!!
Totally appreciate the help
Time to create page: 1.590 seconds
